#11 (permalink) |
I know what I am doing when it comes to electronics enough to screw stuff up. I wouldn't mess with the kit you got for the simple fact that I would screw up the soldering. I went with the kits from Florida Joe. Just my 2 cents.
Led Accent Lights Motorcycle Led Lights Motorcle Accent Ligths Motorcycle Led Lights Motorcle Lights Led Motorcycle Accent Led Lights
2001 GSXR-600-SOLD Custom paint Full LED kit and more strobes then a strip joint. 750cc engine stuffed into a 600 frame 2009 C50 Reckless Fairing -MB Quart 6x9's and Sony media player Mutazu Hardbags Johns lowering kit-3" Johns forward control kit Custom highway bars Florida Joes LED single color kit |
#13 (permalink) |
Don't waste your $, this couldn't be easier. Think of electricity like water. Power and ground like 2 seperate streams. The lights in this case need to both streams to flow to it in order to work.
Start by hooking the power and ground directly to the battery. (50/50 power or ground wire...dont worry if you mix it up, nothing will be messed up) Lights should light up. Now all you have to do is mount the lights where you want them, and run the wires to the battery, making sure to tuck/hide wires along the way. The switch is super easy. All it does is interupt the flow of power. You can place it on either the positive or negative wire. Doesn't matter, but I prefer the negative. I suggest going to a radio shack, getting a tiny little toggle switch 2 positions, and some speaker wire. (The kind with 2 wires side by side. You can just use electrical tape, but I recommend using some spade connectors. Ask the radio shack folks, all this stuff is super easy. I placed my switch in a hidden place in the panel where the tool box is. Look up posts started by me, I have some LED ones that explain more. Good luck!
2007 C50, 3" drop, 2" risers, crash bar, hwy pegs, LED running lights, 1/2 "home boy mod", gutted pipes, spikey grips, custom tail light/license plate. John 14:6 “I am the way, the truth and the life. No one comes to the Father except through me."----Jesus |
#14 (permalink) |
Boogey Lights there the best on the market thats all I USE AND install on bikes u want the cut-click you can go to my photos and check out my bike Have fun
#15 (permalink) | |
#16 (permalink) |
("Quote)The switch is super easy. All it does is interupt the flow of power. You can place it on either the positive or negative wire. Doesn't matter, but I prefer the negative. I suggest going to a radio shack, getting a tiny little toggle switch 2 positions, and some speaker wire. (The kind with 2 wires side by side. You can just use electrical tape, but I recommend using some spade connectors. Ask the radio shack folks, all this stuff is super easy. (End Quote)
As a 40 year master electrician, switches and fuses go on the hot wire. That way when you pull the fuse to work on it you don't get any surprises. Short out a hot wire with no fuse and you got big problems.
'03 Volusia Intruder, Cobra Drag Pipes, K&N air filter, Fatty Knees Bars, Mustang seat, Grasshopper backrest, Wolo horn. Gold wing floor boards and a few other goodies. Last edited by cavie; 01-02-2013 at 11:57 AM. |
#17 (permalink) |
Without seeing your LEDs specifically I am not sure. I am saying to add wires, directly off your battery to run to the lights. And I guess you should run the switch off the power side.
#18 (permalink) |
Wanna come help me..lol.. The Bike is in the shop right know so i wont be able to do this just yet.. i posted a link of what i got.. dont know if he showes anything thow.. thanks for all the help..
#19 (permalink) |
Cavie,
I think what Chubb needs is a simple diagram that he can follow while he is down in the garage. If I was computer literate, I'd try to draw him one and post it. Should be simple as there is not enough of a load to require a relay. What say? |
| The Following User Says Thank You to grunt69 For This Useful Post: | Chub2012 (01-05-2013) |
#20 (permalink) |
I ain't no artist either. No relay required. Not enought load
