Air compressor - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
Old 12-26-2012, 10:14 AM   #1 (permalink)
Vol4Life's Avatar
Default Air compressor
So a family member bought me a Black Friday special because she heard me complaining about having to drive to a gas station to add a couple lbs of air to my bike. It's a cheapo but all I want to do is keep my tires at the correct inflation.
Will a .3 HP, 2 gallon, electric compressor work for this? I can trade up as it came from Lowe's - any recommendations?
Thanks
Vol4Life is offline   Reply With Quote
Old 12-26-2012, 10:31 AM   #2 (permalink)
Wood Welder's Avatar
For what you just described, yes that unit will do the job just fine....However, If you want a unit that is less noise then oil lubed are better. Oil-less air compressors are very noisy.
Thickness can't be measured!
VR WESCALERO MEMBER
Wood Welder is offline   Reply With Quote
The Following User Says Thank You to Wood Welder For This Useful Post:
Vol4Life (12-26-2012)
Old 12-26-2012, 10:35 AM   #3 (permalink)
Vol4Life's Avatar
What about leaks from the oil-lubed compressors?
Old 12-26-2012, 10:39 AM   #4 (permalink)
I've never had a problem with that. Always make sure the vent is in good working order and properly seated and it will serve you well.
VR WESCALERO MEMBER
Old 12-26-2012, 11:13 AM   #5 (permalink)
The general rule for air compressors is buy the biggest one you can afford because once you get into using them they are never big enough.
Sure, the one you got now will inflate tires, but if you think you'll ever be tempted to buy air tools, you'll need much bigger.
I always buy oil lubed compressors, I think they last longer.
USAF 1973-1977
SoDak ANG 1977-2010
Old 12-26-2012, 01:10 PM   #6 (permalink)
mfile2000's Avatar
My cheapo works great for that, and my nail gun (light use one). BUT check a few different tire pressure gauge readings against each other and you might be surprised how different they are.
mfile2000 is offline   Reply With Quote
The Following User Says Thank You to mfile2000 For This Useful Post:
Old 12-26-2012, 01:19 PM   #7 (permalink)
Vol4Life's Avatar
I'm not running any air tools so I guess I will give it a go. And my garage space is limited so no room for a heavy duty model.
I'm still using a $1.99 gauge that fits in my shirt or back pocket.
Old 12-26-2012, 01:31 PM   #8 (permalink)
t-man403's Avatar
Same topic came up on the Valkyrie site the other day.
http://www.valkyrieforum.com/bbs/ind...c,50403.0.html
t-man403 is online now   Reply With Quote
Old 12-26-2012, 06:03 PM   #9 (permalink)
Two Red Ryders's Avatar
Because it was a present your pump will tend to bring you a bit of extra joy.
Old 12-26-2012, 06:10 PM   #10 (permalink)
grunt69's Avatar
@ my age, any pump brings me a lot of joy!
grunt69 is offline   Reply With Quote
