Speedo rattling - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 5 (permalink) Old 12-06-2012, 03:06 PM Thread Starter
Speedo rattling
Hey everyone! I've noticed a rattling sound coming from my speedo on my 06 c50. Does anyone know of a quick and inexpensive way to fix this? It doesn't interfere with the bike at all and it's been happening since I purchased it used back in June, but recently it's just been driving me crazy! It seems like its the glass on the speedo thats just a bit loose, but i've noticed that the whole circular assembly (not the mount itself) rattles a bit when I start it up. Any help with this would be much appreciated!
Diego.Andrade is offline
post #2 of 5 (permalink) Old 12-06-2012, 04:59 PM
dewey405's Avatar
I would pull the chrome housing off (1 bolt IIRC) and check the actual gauge mounts inside, mine had 2 of the 3 broken inside and was causing a rattling.
2009 C50 SE(Grey/Dark Grey) 2009-2012
2012 Vulcan 1700 Nomad
dewey405 is offline
post #3 of 5 (permalink) Old 12-06-2012, 08:42 PM
03volusiarider's Avatar
Or you could put a tank bib on your bike that goes under the gauges.
03volusiarider is offline
post #4 of 5 (permalink) Old 12-07-2012, 04:11 AM
There are 2 plastic catches where u mount the speedo then tighten the screw. See if any are broken. If not, use rubber washers on the two plastic mounts. Then pull the mount so it aligns with the screw and then tighten it. Tht will mount the speedo casing tight.
Againstallodds is offline
post #5 of 5 (permalink) Old 12-10-2012, 03:52 PM
azglocker's Avatar
I glued down the metal ring around the glass to stop mine. It had some double stick tape on it, but that wasn't enough.
azglocker is offline
