Doing my first clutch so far so good, bike in neutral green light on but as I tightened the
the last bolt I swear it sounded like it popped in gear, green light on tire moves free please i need some input. |
Does the tire still spin freely?
Even in neutral, with the rear off the ground there is enough drag for the rear tire to spin with the engine running. If the rear tire doesn't spin freely it's in gear or half in half out. With the engine off check the rear to confirm whether its in neutral or not then cycle between first, second and neutral to see if the light comes on and goes out like it should. |
#5 (permalink) |
My rear tire does not spin in Nuetral while on a lift. Never has in the 3 years I've owned it. Barnett clutch this past summer.
| The Following User Says Thank You to rvcycleguy For This Useful Post: | corys85 (12-05-2012) |
#7 (permalink) |
Not likely. Its exactly where I want the friction zone to be on the lever and cable down at the adjustment screw.
Although, I'd like to see more opinions on this. I would ponder that it's not adjusted properly if the tire does spin?
#8 (permalink) |
Adjusting the clutch to get the rear to spin or not when in neutral will have no effect at all. That is cause by naturally occurring drag in the gears and shafts and becomes more pronounced the thicker the blood you put in the crankcase. On the lift with the engine running in neutral the back slowly turns, grab hold of it it stops. That your's does not would lead me to believe either your rear brake is dragging a little and/or you run closer to the factory recommend 10w40 in the case. If you can't manually spin the rear in neutral you have a seriously dragging brake. really bad bearings, or something horribly wrong in the pumpkin.
| The Following User Says Thank You to dfinitlydisturbd For This Useful Post: | corys85 (12-05-2012) |
#9 (permalink) |
The starter always kicks back upon shut-down due to compression turning the crank back a few degrees, what maybe 20 to 45 degrees. This transfers rotation back through the one-way starter clutch (different clutch) and pushes the starter motor which is normally geared down in the starter-to-engine direction but geared up in the engine-to-starter direction. It is not anything to be worried about. Mine can be heard every time I shut 'er down.
| The Following User Says Thank You to grego For This Useful Post: | corys85 (12-05-2012) |
#10 (permalink) | |
