I have a problem with a front blinker. My blinker indicator is staying on, it is dim but is on, when I turn on the blinker it flashes bright but never goes off. Last night I noticed that my left front marker light is much brighter than the right side, it flashes normal but the marker light is just bright. The indicator light used to intermittenly flash at high speeds (much vibratation) but now it just stays on. Could this be a ground problem? or something else?
Good Times Happen On The Boulevard And The Boulevard Is Suzuki=========================================== In Dog Beers I've Only Had One... ----------------------------------------------------- "metal monsters that let us breathe. Let us smell. Keep us from being numb" -Zookoff |
I think you're right on track with a ground problem... Especially on the blinkers themselves where they ground to the bike frame. A bad ground forces things to be in series that would normally be in parallel by seeking a different ground path. that can casue a couple things to light up that may not normally be.... You get the picture... Anyway I would for sure check the bulbs, sockets, and the ground path for the front blinkers as a starting point...
2011 Victory Cross Country (Black) CeeBailey Windshield (Cee-Dragon) CeeBailey Cee-flector lowers 2005 C50 (Black) (Now my son's bike) V&H Straightshots Pwr Commander DJ drive club member, Nebraska chapter
Are they stock blinkers?
Have you tried changing bulbs??? On the front they are 2 filament bulbs (1157) so they may light but not operate properly. Have you looked at the socket themselves for corrosion?
-Metal monsters that let us breathe. Let us smell. Keep us from being numb. - Zookoff -Twisties give me happy pants Here's to a long life and a merry one. A quick death and an easy one. A pretty girl and an honest one. A cold pint-- and another one!
#5 (permalink) |
Yeah, I think if the run light filament burns out, the turn signal element illuminates and the blinker indicator staying on tells you to change the bulb.
#6 (permalink) | |
__________________________________________________ ______________________________________________"Thunderhoof" Vance & Hines jet kit, K&N, modified pipes, switchblade windshield, dual back rests, license plate relo, tank bib, MCE highway bars, Marlin's clock & thermometer, Kury ISO grips, smoked lenses, Saddleman bags, run/turn/brake controller, PIAA headlight, LED turn signals & running lights,Optronics spotlights, de-paired, "de-Huffied" and de-badged! Kruz Drive Club member. |
#7 (permalink) | |
#8 (permalink) | |
I suppose I don't need to change the air in the tires either !!!
#9 (permalink) |
Ahhh, blinker fluid... I think I keep that next to my metric screwdrivers and 6v battery acid.
#10 (permalink) |
the blinker fluid is just fine (dioelectric grease), both filiments are good and working properly, its just the low filiment (marker) is just bright as heckkkk. I am gonna head on down to the garage and tear the sucker apart (just the front), I'll post up if I find anything.... Wish me luck "I am going in"...
