#22 (permalink) |
can u take a pic of the petcock? The fuel tank probably needs to be removed, and check the hose from the petcock to the throttle bodies and make sure its hooked up and has no cracks. I am not sure on the injectors, but i know they would have to be removed to be cleaned.
Where do you live? Maybe there is a member close by that can help you.
#24 (permalink) | |
I think the next step might be to pull a fuel line from an injector and check if the injectors are getting fuel pressure when you crank. I have the factory service manual in PDF. It's got full, crazy diagnostics. Let me know if you want me to e-mail you a copy.
_____________________________________________ '08 C50T Kuryakyn HyperCharger Intake w/ Stinger Trap Door, American Racing Light Bar, Dobeck Gen 2 FI controller, American Racing slip on mufflers(?), LED mod on Dash Panel, LED Kit, Baron Mini-Tach, DJ Drive Club Member
#25 (permalink) | |
With the WitchHunter Performance when they clean your injectors, they replace the little parts with new and test the injectors so you know they actually work when they are done. They send you a data sheet with the test results. Just click on the underlined info above to be taken to their web site.
The United States of America, founded on the principle that "all men are created equal; with unalienable rights; that among these are life, liberty, and the pursuit of happiness |
#26 (permalink) |
Copied from WitchHunter Performance INJECTOR TIPS- Keeping injectors healthy.
Keeping your Fuel Injectors healthy ![]() Keep you gas tank full, especially if the car sits for extended periods. This will help keep water out of the fuel system. Add a water remover about twice a year. Use a good brand of in-the-tank fuel injector cleaner to help keep your injectors and intake valves clean. Use them a couple times a year, and only as directed... using more than recommended amounts can damage the injector coil insulation. Change your fuel filter per manufacturer recommendations. Inspect any fuel lines for hardening or deterioration. Some injector's terminals are prone to corrosion. Clean and use silicone grease in them. Older connectors can get brittle due to the heat, replace damaged connectors if needed. If your injectors are removed, it may be a good time to send them in for servicing. At a minimum, replace the o-rings and seals. Never soak fuel injectors in harsh chemicals like; injector cleaners, Seafoam, acetone, etc. This can cause damage to the coil insulation and internal seals. Besides, you can't get them clean by soaking. Trying to clean them in your wife's jewelry ultrasonic cleaning tank usually won't work well either. Any form of cleaning should be followed by testing to verify the results. Don't use excessive force when installing injectors into the rail or manifold or the o-rings may get damaged. Use clean motor oil to lube the o-rings and rotate the injector during installation. If it doesn't want to go in, remove it and try again. The pintle cap is the plastic piece on the bottom of the injector. It protects the "business end" of the injector, holds the o-ring, and insulates the tip. Be careful not to damage them since they become brittle with age. Don't let injectors dry out when they are out of the car. Store them in a plastic bag and keep them indoors. Be aware that they may stick closed after a time. A 9 volt battery can be used to check for stuck injectors, listen for a click. Don't use the car's battery for testing, it can overheat the injector coil, (especially low impedance injectors). Just because an injector "clicks", it doesn't mean that it flows correctly, it just indicates it's not stuck. If injectors are stuck after sitting for a short time, sometimes a "tap" with a small hammer on the metal body can free it. Don't break anything... I said "tap". If that doesn't work, send them to us. It may be a good idea to paint the metal body of the injectors to keep them from rusting. Standard engine paint works well and can be purchased at your local auto parts store. A good water removal is Alcohol when I use to live in a colder winter area you could rock the car back and forth in the winter and hear the ice hitting the side of the car's gas tank. We use to add a water remover which was basically Alcohol. Currently most fuel injector cleaners have an alcohol base or at least 25% alcohol like Seafoam. With Ethanol basically 10% Alcohol there is less of a need for me to add Alcohol to my gas tank.
The United States of America, founded on the principle that "all men are created equal; with unalienable rights; that among these are life, liberty, and the pursuit of happiness Last edited by Two Red Ryders; 11-28-2012 at 02:31 PM. |
