Whistleing Noise!! Help - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
Old 12-07-2012, 04:17 AM   #11 (permalink)
Could be the air escaping from the hose the connects the air cleaner. Did u remove the thank and remove the hose from the throttle body?
Remove the air cleaner, check if the metal ring securing the hose is in good shape and not bent up. Then loosen the ring. Put the air cleaner in, tighten the ring then mount the aircleaner to the engine with the screws. Its tight around there. Hope u have long screwdrivers and long allen keys
