Will not start? - Page 3 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
Old 10-12-2012, 05:47 PM   #21 (permalink)
rvcycleguy's Avatar
Originally Posted by zfmrchnt View Post
New battery on a fresh charge did nothing, no crank, no noise, but all the lights work.
I did notice that I could up shift through all the gears with no clutch but never down into into first with or without clutch?
How did you charge the new battery? Did it come with acid in it already or did it come dry and you added it?
2006 C50c
White with ghost flames
2010-Guanajuato, Mexico
3 Sisters- Texas Hill Country
2011-Key West, FL
Sedona,Grand Canyon, AZ
2012-Big Bend,Texas
PCH- LA to SF rt.
Old 10-12-2012, 06:15 PM   #22 (permalink)
zfmrchnt's Avatar
dry
zfmrchnt is offline   Reply With Quote
Old 10-12-2012, 06:37 PM   #23 (permalink)
Default Moisture in starter switch or
Clean the battery terminals, WD in starter switch assembly, WD in side stand kill switch. My money on the starter switch being moisture ridden.
:_)
Wayne Dupuis
Victoria, British Columbia
oops is offline   Reply With Quote
Old 10-12-2012, 07:17 PM   #24 (permalink)
rvcycleguy's Avatar
dry
Ok. Just for basic procedure, a dry battery must be slow charged ( 2-3 amp) for 6 or more hours, then sit for an hour or two. It's a long process. It's more than just adding electrolyte and fast charging and expecting the battery to be ready.
If you did not use this basic procedure, the battery is not necessarily optimal yet.
2006 C50c
2011-Key West, FL
2012-Big Bend,Texas
PCH- LA to SF rt.
Old 11-20-2012, 12:05 PM   #25 (permalink)
zfmrchnt's Avatar
Battery has been charged correctly
Could this be a Starter Solenoid issue?
Old 11-20-2012, 12:26 PM   #26 (permalink)
03volusiarider's Avatar
could be. if you are not getting a ( Click) from the starter solenoid. Cross the terminals with a screwdriver and see if it starts.
03volusiarider is online now   Reply With Quote
