Rear tire bounce - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
Old 02-22-2012, 10:27 AM   #1 (permalink)
smjones13's Avatar
Default Rear tire bounce
So I'm slightly mechanically inclined but I have never had to do this before and I'm not sure of how to go about it. I'm pretty sure my rear tire isn't balanced. When I go over 10 mph it starts to bounce a little. At first I just thought it was the road (roads are horrible around here) but I have had it on new pavement and its still doing it. How do I go about fixing this and can I do it myself or do I have to take it to a shop?
Sent from my Motorcycle iPhone app
smjones13 is offline   Reply With Quote
Old 02-22-2012, 10:39 AM   #2 (permalink)
desim's Avatar
Check the air. Check the tire for a defect. If all is ok I recommend Dyna Beads.
CB350, TS400, Rebel, GS750, suzuki 650 savage, 2008 Blue & Silver C50 sold, 2007 Silver Ghost Flames C50C
Any married man should forget his mistakes, there's no use in two people remembering the same thing
desim is offline   Reply With Quote
Old 02-22-2012, 10:41 AM   #3 (permalink)
~Capt Creole~'s Avatar
At 10 mph, that sounds like your rim isn't true. I'd check that first and true up the spokes if thats the problem.
Laissez Les Bon Temps Rouler "Let the Good Times Roll" WHO DAT SAYS DEM SAINTS DON'T WIN?
~Capt Creole~ is offline   Reply With Quote
Old 02-22-2012, 11:21 AM   #4 (permalink)
Check the tire for cupping as well.
Old 02-22-2012, 11:28 AM   #5 (permalink)
Slightly mechanically inclined? I'd seek professional help as your safety may rely on it. Why mess around.
Sent from my Motorcycle iPad app
jayelwin is offline   Reply With Quote
Old 02-22-2012, 11:38 AM   #6 (permalink)
smjones13's Avatar
Service shop wants to charge 200 to true the wheel! Seems like alot to me.
Also can you use beads with a tubed tire?
Old 02-22-2012, 12:02 PM   #7 (permalink)
Is the rim out of alignment for sure?
yes, you can use dynabeads in a tubed tire.
Old 02-22-2012, 12:50 PM   #8 (permalink)
SMJONES,
I guess for my information or for others that may be curious.... what year is your bike?, how many miles? How often do you ride it? Did you run over debris, or curbing? have you tapped the spokes to determine, for yourself, if some are loose or broken? You may chime back and say none of my business, but its always helpful here to understand how, why, and what for so that other riders can benefit from your unfortunate situtation, down the road, so to speak. Thanks, rv
2006 C50c
White with ghost flames
commander, K&N, leatherlyke bags, tour backrest, 3 pc mustang, bars, cobra boards, light bar, driving lights, shield, vista, tank bib, stebel, white walls, dj drive
Old 02-22-2012, 02:15 PM   #9 (permalink)
smjones13's Avatar
No problem. Bike is an '06 C50. Daily rider to and from work (only about 10 miles each way) with about 5000 miles on it. Like I said, the roads around here are crap so I hit a lot of cracks and small bumps but nothing worth mentioning. Only other bike I had was a sport bike so this is my first experience with spoked rims
Old 02-22-2012, 03:12 PM   #10 (permalink)
I bet you lost your wheel weights that happened to me. Dyna beads or ride-on will cure the problem without taking the wheel off.
johbren1 is offline   Reply With Quote
