Coolant - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
Old 08-12-2011, 06:31 PM   #1 (permalink)
Question Coolant
can coolant be added with out removing the fuel tank ? I took off the lower cover and the resevoir is empty.
You don't know when you wil be here again so try it, the worst thing that could happen is you die. If you don't then its good.
Bob O is offline   Reply With Quote
Old 08-12-2011, 06:51 PM   #2 (permalink)
You can add to the coolant bottle, however, since that is empty, personally I'd remove the fuel tank, and physically check the radiator itself.
Probably a good time to change the coolant, if that's needed.
Psyc0 is offline   Reply With Quote
The Following User Says Thank You to Psyc0 For This Useful Post:
Bob O (08-12-2011)
Old 08-12-2011, 07:18 PM   #3 (permalink)
It is not really necessary to remove the tank. I just finished changing my coolant. All i did was take the bolt out at the rear of the fuel tank and slide the tank back until i could see the rad cap. I then used a piece of 2x4 to hold the tank up at the back and had my wife steady the tank just in case. Worked like a charm.
Henry
henry postma is offline   Reply With Quote
Old 08-12-2011, 09:25 PM   #4 (permalink)
Boxwrench's Avatar
use aluminium friendly stuff.
premix or you mix.
I use Engine Ice premix for motorcycles.
works better than normal AND less toxic to 2 and 4 legged critters.
Been told by some here it isn't as great for winter.......up north........where I DON'T live.
A weird thing about that stuff........
I got a hold of an old container of the stuff from a machine shop move and the plastic bottle ( heat and age) was so brittle that it broke while bringing it in to a friends house and the contents spilled all on the concrete.
That was a many months back and the black mold stain we get down here went away and hasn't been back yet where it spilled.
Boxwrench is offline   Reply With Quote
Old 08-12-2011, 10:36 PM   #5 (permalink)
sammyj's Avatar
According to the Owners Manual "Engine coolant is harmful or fatal if swallowed or inhaled"
<a><img></a>
sammyj is offline   Reply With Quote
Old 08-12-2011, 11:09 PM   #6 (permalink)
Boxwrench's Avatar
didn't say it was non toxic....just less so.
last longer to get treated.
Old 08-13-2011, 03:32 AM   #7 (permalink)
Hi-Vis's Avatar
Somewhere I read that deionized water (not just distilled) mixed with conventional non-silica antifreeze is the same as engine ice.
I predict it won't be long before antifreeze as we know it will be banned.
Just a teaspoon causes kidney failure on dogs.
Special Edition 2009 C50 Green/White . 13600 miles. Loaded up and then some!
ATGATT Sweat, not blood.
Old 08-13-2011, 08:27 AM   #8 (permalink)
Boxwrench's Avatar
A slow and very painful death.
Lost 2 cats to a woman who did it cause she didn't like dusty paw prints on he jap sports car so laid out a pan of water w/ it in on a hot day to poison every animal on the street.
A fine able act here, trouble is proving it.
Next door managed to save theirs ........mine not so.
Is why I try to use the less toxic products or more care and cleanup even for accidental spills.
Old 08-15-2011, 12:03 PM   #9 (permalink)
DrBLVD's Avatar
Sorry to hear about the cats, but the less toxic antifreeze does not work as well as the cat-killer variety.
I'd rather see a dead stray than have a dead C50.
As a biochemist I can tell you the difference in DIH2O vs Distilled H2O is almost negligible when using it in a motor that has metal parts. The second that water hits the engine, guess what, it's not distilled nor deionized anymore.
Why use a big word when a diminutive utterance would suffice?
DrBLVD is offline   Reply With Quote
Old 11-18-2012, 06:38 AM   #10 (permalink)
Just out of curiousity, what has higher heat transfer capability? Distilled water, drinking water or antifreeze?
