Drain Plug Crush Washer - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
Old 10-08-2009, 03:29 PM   #1 (permalink)
Default Drain Plug Crush Washer
Which way does it get installed on the drain plug?
I assume that the flat side of the crush washer goes on the flat par t of the drain plug and the rounded side goes towards the motor.
Thanks,
h00k247 is offline   Reply With Quote
Old 10-08-2009, 03:35 PM   #2 (permalink)
Wood Welder's Avatar
yup
Thickness can't be measured!
VR WESCALERO MEMBER
Wood Welder is offline   Reply With Quote
Old 10-08-2009, 03:38 PM   #3 (permalink)
I need a new one for both my oil drain and my drive drain bolts.... Anyone know if I can get them from Advance Auto or Autozone?
- 2005 Boulevard C50 - 7-2008 to 5-2012
- 2012 Vulcan 900 - 5-2012 to Present
Any idiot can run a marathon. It takes a special sort of idiot to run an ultra-marathon!
Skrapiron is offline   Reply With Quote
Old 10-08-2009, 03:44 PM   #4 (permalink)
Counter Steer's Avatar
They have the 1/2" copper washers, some use those instead of the crush washers.
Last time I bought them, crush washers were a $ 1.00 a piece at my local dealer. I usually by a handful of them just so I have them handy. I install them the same way the first one was installed. Curved side towards the bolt head, flat side toward the pan. The original factory installed washer was on that way.
I use a new washer about every three oil changes. By that time they are getting pretty flat and it is before they show any wear. You can use the 1/2" copper washers the same way. As soon as they showed any scratches or flattened areas I replaced them. Three times seems pretty safe. At a $ 1.00 each from the stealer or $ 0.40 each for 1/2 copper drain washers at Napa they really could be changed every time.
Wescalero Rider
Mhac nan con
"If there must be trouble, let it be in my day, that my child may have peace.” Thomas Paine
Counter Steer is offline   Reply With Quote
Old 10-08-2009, 05:13 PM   #5 (permalink)
scorpio_vette's Avatar
Send a message via MSN to scorpio_vette Send a message via Yahoo to scorpio_vette
LOL..........i always forget about those washers until the oil change. then as i'm going to put the drain plug back in i think: "**** i forgot again. i really should find those somewhere and buy some for next time".
then the bike is due for an oil change again.
i think i have about 5 oil changes on my bike now and still haven't remembered to get a new washer. i just run the bike for a couple minutes after the oil change and keep and eye on the plug/washer, and then take it around the block a couple times and check it again. LOL so far i haven't had to borrow the wifes bike to go find a new washer. LOL
scorpio_vette is offline   Reply With Quote
Old 10-08-2009, 06:18 PM   #6 (permalink)
Banned
mine ain't never had no washer on it.
mightydog is offline   Reply With Quote
Old 10-08-2009, 06:24 PM   #7 (permalink)
If you look close its there. You can slip your knife in the crack at the bolt head......Easy to put new one on but, hard to get the old on off.
I have to replace the diff. crush washer every time but can get away with three oil changes on the engine oil.
VR WESCALERO MEMBER
Old 10-08-2009, 06:32 PM   #8 (permalink)
Banned
if i can't tell it's even there, why worry about replacing it? never saw any leaking.
Old 10-08-2009, 06:35 PM   #9 (permalink)
Very true.
VR WESCALERO MEMBER
Old 10-08-2009, 08:38 PM   #10 (permalink)
PhilJet's Avatar
The Advance Auto by my house has aluminum drain plug washers. I just bought a variety of sizes for multiple vehicles. I use a new one every time.
"Don't take yourself so seriously, no one else does."
"It wouldn't hurt us all to be a little more grateful."-A.B.
'01 Black & Red Volusia - sold
'09 Black FJR
PhilJet is offline   Reply With Quote
