Disabling PAIR Valve - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 9 (permalink) Old 05-13-2009, 07:10 PM Thread Starter
I'm trying to disable the PAIR valve on my '08 C50 because I'm getting quite a bit of popping on decel. However, when I removed the cover I discovered that my setup doesn't look like the one pictured on Moccs Place. The instructions there say to plug the bottom hoses but mine has one hose coming in the side and two straight out the back one above the other. I could probably remove the tank and follow the lines but I'm still not 100% sure where the lines go to that need to be plugged. Anyone with an '08 C50 or knowledge of one that can point me in the right direction?
Thanks,
Munque
2008 Suzuki Boulevard C50SE
GMan Bushing, Kury ISO Grips, Cobra Freeway Bars, Cobra Streetrod Slashdowns, Bully FI Controller.
It's my show and you're all just supporting actors!!
Munque is offline
post #2 of 9 (permalink) Old 05-16-2009, 08:07 AM
I have an 06 C50 and my pair valve had been fine until very recently. 24K miles and I am also looking for specific disabling instructions for the fuel injected version.
2006 C50 -->> 2007 R1200RT
Previously known as "Bikingagain"
Flylow is offline
post #3 of 9 (permalink) Old 05-16-2009, 10:34 AM
danimal's Avatar
do you have the 2 chrome looking hoses that feed into the cylinders? I just plugged those up on my 05 rather than marbling the existing hose. I had done the hose thing at 1st and the hose deteriorated from the engine heat and started leaking so I just plugged the metal hoses with vacuum plugs, a little permatex, and hose clamps.
I took the whole pair assembly off and tie wrapped the solenoid to the frame under the tank.
danimal is offline
post #4 of 9 (permalink) Old 05-16-2009, 12:25 PM
Smithy's Avatar
The third hose goes straight across to connect to the back of the air filter housing (football). When I disabled mine, I plugged that hose on both ends. I'm not sure if it's necessary to plug that hose, but it didn't hurt anything.
Mike
Don't ride through western Oregon without stopping to say hi!
www.facebook.com/therealmikesmith
Proud to be a VR Wescalero
Smithy is offline
post #5 of 9 (permalink) Old 05-16-2009, 10:20 PM
pac50t's Avatar
I disabled the PAIR using Mocc's kit on my '06 only months after getting it. Very easy. I'll talk to you about it tomorrow when we ride to Port Jervis.
Some people think that they know. But, they don't know enough to know that they don't know.
http://www.volusiariders.com/viewtopic.php?t=51362
http://www.facebook.com/album.php?ai...9&l=eeb1a3e8b5
pac50t is offline
post #6 of 9 (permalink) Old 05-17-2009, 12:51 PM
Mr P's Avatar
I plugged the two hoses coming out of the back of the valve with golf tees. Mine is an 08.
Have not noticed much difference in 3k miles.
2009 Piaggio Mp3 500 (El Stiffo)
Your fingerprints don't fade from the lives you touch...
Mr P is offline
post #7 of 9 (permalink) Old 05-19-2009, 11:25 AM Thread Starter
Thanks Mr. P, I also have an '08 and I thought those were the correct hoses to plug and you have now confirmed it for me. I will be plugging them up tomorrow.
Munque
Munque is offline
post #8 of 9 (permalink) Old 05-25-2009, 08:26 PM Thread Starter
I would like to thank everyone yet again for their help. I've been away off and on alot lately and haven't had much time to work on the bike. However, today I got out a couple of golf tees and disabled the PAIR valve and it took away probably about 90%+ of the popping I was getting on decel.
Munque
Munque is offline
post #9 of 9 (permalink) Old 06-01-2009, 09:46 PM
jmikew's Avatar
I just de-Paired my 08 and boy was the front one was hard to do -- there wasn't anything easy about it. Now the back one was easy. I hope that you all have small hands, or know someone who does.
It does sound better now.
For all those who aren't sure about the hoses on the 08 with fuel ejection, its the same as on the instructions. There are 3 hoses -- one connects to the tube that goes to the front, one connects to the tube that goes to the back and one that goes to the backside of the air filter box (unless you have already switched to an after market air filter box, then you have already disconnected the air hose). There are no vacuum hoses to disconnect on the C50.
2008 Suzuki C50 Boulevard Owner
jmikew is offline
