How to fix your Ignition Switch - Page 11 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
Old 09-21-2012, 08:03 PM   #101 (permalink)
Harryp. Thanks for the great illustrated and informative description for ignition switch problem repair.
Ronzo is offline   Reply With Quote
Old 10-10-2012, 02:55 PM   #102 (permalink)
Oklahoma_mike's Avatar
So I am having this issue right now. Bike acts like dead battery so lights or anything 30amp fuse is fine and if I jump the starter solenoid she will crank. She broke down in a restaurant parking lot so I got a ride and will be running home to get some tools and give this a try. I will let you know if this doesn't fix it and update with the resolution. Thanks for posting this repair!!!
Oklahoma_mike is offline   Reply With Quote
Old 10-11-2012, 09:07 AM   #103 (permalink)
This wasn't the issue on my bike. Mine had an issue with one of the pins inside the green connector. It looked as though it got a little too hot.
Old 11-05-2012, 10:35 PM   #104 (permalink)
harryp, thanks so much for you detailed post about the switch repair had to fix one to night for a friend and this was spot on. Due to you detailed post the repair took only thirty minutes to fix and had his back on the road.
will do is offline   Reply With Quote
Old 02-14-2013, 09:22 PM   #105 (permalink)
13thman's Avatar
Wooohoooo! this fixed my ride!
No signs of heat but the contacts on the black pad looked faded so I hit then with some fine sandpaper put the lube on and slapped it back together.
2moro I'll put in the relay for the light bar just to be safe and while i have the tank off I want to swap out the coolant.
Thank so much harryp for the very helpful post!
13thman is offline   Reply With Quote
Old 03-11-2013, 06:29 PM   #106 (permalink)
You just saved me alot of heartache thanks
volusiaphil is offline   Reply With Quote
Old 03-27-2013, 02:04 AM   #107 (permalink)
Default bolts are round
i opened the tank and plastic covers to get access to the ignition assembly. i discovered that the bolts holding the ignition assembly are round so a torx bit would not work. anyone know how to get around this?
suncowiam is offline   Reply With Quote
Old 03-27-2013, 08:39 AM   #108 (permalink)
Go to Ace Hardware and get you a torx security bit. I don't remember what size, I think they sell a set for $9.
USAF 1973-1977
SoDak ANG 1977-2010
Old 03-30-2013, 12:43 PM   #109 (permalink)
Two Red Ryders's Avatar
Seems like a lot of work to lube the ignition switch. If I had a problem with the ignition I would first spray the switch with Corrosion Block and operate the switch a few times Corrosion Block is available at West Marine and on line. I have been using corrosion block for years it fixes lots of electrical problems with switches and connections etc. It both lubes and cleans electrical contacts and switches.
Old 03-30-2013, 01:02 PM   #110 (permalink)
For those running a lot of extra lights etc one of the best ways to prevent trouble with your ignition switch from over heating is to run the extra light load via a headlight relay drawing directly from the battery. Not only will the relay protect your ignition switch but it often will make your auxiliary lights or more powerful Headlight brighter.
