#11 (permalink) |
I'd change the brake fluid as it's not hard to do, and see if that makes any difference. I'm thinking it's the valve in the master cyclinder that's perhaps vibrating (harmonic) as the fluid is going through when you squeeze the brake handle. I don't know what else would make the type of sound you describe...
#12 (permalink) |
It's not normal on a C50. Try putting it in neutral while sitting in your driveway or on the street and engage the brake lever. If it doesn't make the sound then you can rule out the brake reservoir. If it only does it when you're moving it could be the brake line hitting something, the pads, or something else with the front wheel transmitting the noise up through the brakes.
#13 (permalink) | |
| The Following User Says Thank You to rvcycleguy For This Useful Post: | Whiskey (12-01-2012) |
#14 (permalink) |
I got a chance for a quick ride when I got home today and noticed some stuff thanks to your suggestions. The noise only happens when I'm moving and deteriorates as I slow down. It definitely sounds like it's coming from the lever/reservoir area, not the caliper area. This is making me think that it's something rubbing in the pad/caliper area and the noise is transferring up the line or cable. I'll try to pull it apart this weekend and identify the culprit, but honestly I've been through weird stuff like this and usually I pull it apart, inspect everything, put it back together and the noise goes away without me ever knowing the root cause. Oh well, I'll take it one way out another. Again, thanks for everyone's help.
Music, Motorcycles, and Family... Nothing else really matters in life! 2006 Boulevard C50 |
#15 (permalink) | |
| The Following User Says Thank You to Whiskey For This Useful Post: | rvcycleguy (12-01-2012) |
#16 (permalink) | |
The United States of America, founded on the principle that "all men are created equal; with unalienable rights; that among these are life, liberty, and the pursuit of happiness |
#17 (permalink) |
Gee thanks, but actually the noise isn't there if you don't pull the brake. Apparently the holes only make the sound when the pad makes contact. Personally, I suspect it had something to do with the groove in the pad, but what the **** do I know!
#18 (permalink) |
With the new disc and pads on mine, I hear that noise when not using the brake, but is very faint now with over 1,000 kms on the new brakes. The noise is still there under braking. I didn't hear the noise with my old disc, but that is probably more to do with the poor condition of the disc surface.
