Boulevard 50 Series Question - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
Old 11-13-2012, 01:50 PM   #1 (permalink)
Default Boulevard 50 Series Question
Looking at the Boulevard 50 series and am interested i ngetting thoughts on S50, C50 & M50. Concerned about the S as I live in WI & like cold weather rides. Any issues w/starting the S in cold weather?
Thanks
Hdsteal is offline   Reply With Quote
Old 11-13-2012, 02:13 PM   #2 (permalink)
gsimmons's Avatar
I've got a fuel-injected C50 in Ontario, and it starts right up regardless of the temp.
gsimmons is offline   Reply With Quote
Old 11-13-2012, 02:50 PM   #3 (permalink)
All are mostly same just cosmetic differences. But c50 looks better with accessories.
Cold weather start i guess fi bikes have lesstrouble than carb
Old 11-13-2012, 02:51 PM   #4 (permalink)
mfile2000's Avatar
No problem starting mine all winter long.
mfile2000 is offline   Reply With Quote
Old 11-13-2012, 06:04 PM   #5 (permalink)
Jendesigner's Avatar
The C50 and M50 are closer to each other but the S50 is a different bike altogether. The feel, ride, weight and overall stance is different. Yes, it is a carb (C50 and M50 are FI) and it is cold blooded but if you rejet you won't have a problem. I'm not far from you and after going nekkid with my Vol starting when cold is no problem, rode down to 18 degrees (actually all my bikes are carbs, no problem in cold weather, warm up time is just a bit longer). If you can do test ride all 3 and see what you like and dislike about each.
Jen / "All leather, no lace"
Old 11-13-2012, 07:03 PM   #6 (permalink)
b12pointer's Avatar
I think the C50 and the M50 have better resale then the S50. I have A 09 C50 and live in Iowa.
b12pointer is offline   Reply With Quote
Old 11-16-2012, 08:37 AM   #7 (permalink)
Nick C2's Avatar
The S50 is a great bike, loved the 07 I had. But they don’t like the cold.
Nick C2 is offline   Reply With Quote
Old 11-16-2012, 10:21 AM   #8 (permalink)
dfinitlydisturbd's Avatar
I've yet to see a carbed suzi 800 that likes the cold, especially if 10% ethanol is all that's available to feed it.
Be aware that FI did not hit the Volusia line. While the C50 is basically the same bike and VL800, Volusia, and C50 tend to be used fairly interchangeably if you want FI you're going to be looking at 2005 or later C50, M50. The S50 appears to have never gotten FI, but instead has dual carbs.
If you're willing to deal with a little cold weather stubborness and mandatory fuel stabilization additives at almost every fuel up (unless you are able to get gas without ethanol in it) in when it gets cold all will start fairly easily. All make roughly the same amount of HP. But there is a pretty significant difference in weight between models C50 (610lbs.), M50 (584lbs.), S50 (535lbs.), VL800 (526lbs.). There really is no best choice between them as all are nice bikes. If you like the S50 go for it, as long as you add a good fuel stabilizer with fill ups it will start and run without much if any hassle.
Old 11-16-2012, 11:53 AM   #9 (permalink)
Thunderhoof's Avatar
Originally Posted by dfinitlydisturbd View Post
But there is a pretty significant difference in weight between models C50 (610lbs.), M50 (584lbs.), S50 (535lbs.), VL800 (526lbs.)...
On a side note: I didn't realize the C50 weighed that much more than the Vol. That can't be due to just the F.I. gobblygook?
"Thunderhoof"
Old 11-16-2012, 03:25 PM   #10 (permalink)
...if you want FI you're going to be looking at 2005 or later C50, M50. The S50 appears to have never gotten FI, but instead has dual carbs.
It was my understanding that the C50 and M50 got fuel injection in the 2006 and later models; the 2005 and previous were carbs (non-FI).
TheRealMoleman is offline   Reply With Quote
