How To Drain Your Carburetors (step-by-step, with pics) - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
Old 11-02-2012, 03:00 PM   #11 (permalink)
Default Stabil in the tank
I put stabil in my tank and let it run I just haven't drained the carb because I've heard conflicting reasons. Just curious as to which needs done. Thanks
Volusia_dlc is offline   Reply With Quote
Old 11-02-2012, 03:34 PM   #12 (permalink)
MrChili's Avatar
Originally Posted by TranscendBen View Post
Hello Volusia Riders,
Can someone please reply with a step-by-step (pics if possible) on how to drain my carburetors for the Canadian winter. I was told this is very important.
I have a 2001 Suzuki Volusia VL800
Cheers
I'm an hour north east of the GTA and I've had a 2002 VL800 for the last six winters. I've never drained the carbs, in fact my "winterization" routine is quite suspect. I pour half a can of seafoam into the tank and make sure the snowblower is behind the Vol. Oh, I keep it on a battery tender over the winter.
The bike runs like a charm, it's pain getting her first started in the spring, (about a 15-20 minute chore) but once she gets going she has always run like a charm for the entire season. If there is a nice mild dry winter day and the itch is too much for me to scratch, I've taken her out for a ride. I just make sure I run her long enough to get good and warmed up.
Personally I'd only worry about draining the carbs if you're looking at long term storage.
Regards
Old too early.....Smart too late.
MrChili is offline   Reply With Quote
Old 11-02-2012, 05:28 PM   #13 (permalink)
Step 1 turn on ignition key
Step 2 depress starter button
Step 3 ride until you run outta gas!
mdhyre is offline   Reply With Quote
Old 11-02-2012, 09:36 PM   #14 (permalink)
dfinitlydisturbd's Avatar
We have a winner!
Old 11-05-2012, 07:16 PM   #15 (permalink)
Seriously, I did this by accident when I flushed the radiator. I forgot to reattach the vacuum line that leads to the auto fuel shut-off. I didn't know what it was at the time but I started it and it ran out of gas (i.e. drained the carbs) in about 45 sec. The line is on the LH side under the gas tank. Pull it off and start it up.
I agree with MrChili. I believe it is better to store a carb wet to keep the diaphragms and gaskets from drying out. What I do is put some Sta-bil or Sea Foam in the gas along with some Lucas fuel treatment (because it is oil base) in the tank, mix it up and run it until you're sure its in the carbs. The bike will start in the spring. It might take a bit of work but the gas will not have turned to turpentine. I did this with my lawnmower and it worked great.
Old 11-05-2012, 07:30 PM   #16 (permalink)
Seriously, I liked your answer better before you added--^
