Relocate Helmet lock - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 12 (permalink) Old 08-08-2007, 11:15 AM Thread Starter
I've recently added saddle bags rendering helmet lock unaccessable. Any suggestions on how and where to relocate lock?
StPeteBiker is offline
post #2 of 12 (permalink) Old 08-08-2007, 11:23 AM
Bikerbrackets is a website to look at. And befoer Vo1rider shows up..... do a search for your topic, lots of threads about it.
2008 Kawasaki Nomad
2006 Suzuki C50
2006 Suzuki DR200SE
2001 Yamaha PW80 ( grandsons )
"If you ride like there is no tomorrow, there won't be "
jimr is offline
post #3 of 12 (permalink) Old 08-08-2007, 12:36 PM Thread Starter
Thankx for the suggestion. Didn't know there was a search option. I do now.
post #4 of 12 (permalink) Old 08-08-2007, 12:56 PM
Glad to help ! Welcome aboard !
2008 Kawasaki Nomad
2006 Suzuki C50
2006 Suzuki DR200SE
jimr is offline
post #5 of 12 (permalink) Old 08-08-2007, 01:32 PM
There are a couple of solutions besides re-locating the existing helmet lock. One is to iinstall a Kuryakyn Universal Helmet Lock, whick clamps around a 7/8" to 1 1/4" pipe (such as frame rail or the highway bars). They also make one for larger tube mounting, which might fit the fork tube.
Then there is the one that mounts on the end of the Iso-Grips, if you happen to have them. It's a clean, finished looking tapered tip, which has a tubular key-lock on the end, and a slot to accept the 'D'-ring.
A lot of the members have moved the existing lock, and there are some photos and how-to's to be found on a search.
Lot's of choices.
'04 Volusia,
At the Beach,
Slower lower Delaware
Will is offline
post #6 of 12 (permalink) Old 08-08-2007, 01:34 PM
pbryon's Avatar
There's also one that replaces the license plate frame and gives you two locks, one on each side of the license plate. I forget the name, though.
pbryon is offline
post #7 of 12 (permalink) Old 08-08-2007, 01:51 PM
TNrookie's Avatar
I think I saw in the last J&P catalog that the same company that makes the end-of-grips one for the ISO's (KewlMetal, I think) has started making one for our OEM grips. I'll see if I can't find a link or part number
Voila....They replace the stock bar weights.
aka RockyStop, TNsmartass
Chairman and Co-Founder, Stebel CYFHMN Club
'02 Nomad 1500
Bikes I Miss:
'04 Volusia (Black)
'07 C50 (Red/Black)
'04 Volusia (Blue/Gray)
TNrookie is offline
post #8 of 12 (permalink) Old 08-08-2007, 02:21 PM
foambuilder's Avatar
Move helmet lock
There is a thread called "OEM helmet lock mounted to front fender in vertical position" here at VR. It is by jet987. He moves the lock to the RF brake mounting bolt area.
I didn't like that location because of a hot brake rotor, but it works. I think it would be better on the LF side, using a fender bolt.
Anyway, think about it and see what you like.
2011 Victory Cross Country - White/Silver
SOLD 2006 C50c Pearl White w/Silver-Gold Ghost Flames
"It's never too late to ride the ride of your life!" - quote from Burt Monroe
foambuilder is offline
post #9 of 12 (permalink) Old 08-08-2007, 04:41 PM
SCChuck1's Avatar
I tried the relocate bracket for a while and was unhappy with it. It worked fine, just not what I wanted.
I really like the kury grip end locks. I have one on either grip for a balanced look and the ability to lock two helmets. they are expensive but work well and look good - like part of the bike rather than an add-on.
If you go with those, don't lock your helmets outside when you're expecting rain. You will only do it one time. I, of course, am smarter than that.
SCChuck1 is offline
post #10 of 12 (permalink) Old 08-08-2007, 04:49 PM
tropicalhotdog's Avatar
http://www.lockitt.com/accessories_helmet_holders.htm
tropicalhotdog is offline
