DJ Drive by Motiv - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 12Likes
post #1 of 16 (permalink) Old 12-06-2016, 09:45 AM Thread Starter
EL Pistoffo's Avatar
DJ Drive by Motiv
It's been over a month and a few hundred miles since I installed a DJ Drive supplied by Motiv on my '06 C50. The drive has been a dream. The gears are more useful, less shifting required, 5th gear rarely needed when driving around town. Riding at higher speeds is far more comfortable than before. I don't ride on the highways so I seldom exceed 70 MPH. This drive has also gotten lots of 2-up riding. A little adjustment on throttle and clutch use is needed with the new rear end ratio but very easy to adjust as a rider even for a noob as myself.
The drive itself was excellent. It was shipped promptly and well packaged. Motiv provided everything needed to install except the tools. Moly grease, spacer, etc. was included as well as installation tips. Any questions about the drive or installation was met with a prompt response from Motiv himself.
Overall an amazing upgrade with great support. I definitely recommend Motiv's drives.
'06 C50
This message is being monitored by the NSA
EL Pistoffo is offline
The Following User Says Thank You to EL Pistoffo For This Useful Post:
scottbass (12-06-2016)
post #2 of 16 (permalink) Old 12-06-2016, 10:44 AM
scottbass's Avatar
That is exactly my experience with Motiv as well - fantastic support!
EL Pistoffo likes this.
2012 C50T
scottbass is offline
post #3 of 16 (permalink) Old 12-06-2016, 08:09 PM
Me too. Motiv made it a lot easier than I thought it would be. Great instructions.
Sent from my SM-G930VL using Tapatalk
superchet is offline
post #4 of 16 (permalink) Old 12-09-2016, 02:49 PM
romoore's Avatar
+one! Same Here.
romoore is offline
post #5 of 16 (permalink) Old 12-18-2016, 07:10 AM
GregWork's Avatar
same here!
2006 C50T Blvd
GregWork is offline
post #6 of 16 (permalink) Old 12-18-2016, 07:18 AM
Best upgrade you'll make. They folks here are the best you'll find.
post #7 of 16 (permalink) Old 02-04-2017, 01:55 PM
TonyC50T's Avatar
I have seen a couple of posts that mention that a hole (I believe it is for the bolt/shaft that holds the wheel in place) for the drive shaft needs to be elongated. If that is the case, I am not comfortable doing that to my bike and wouldn't do it. Can someone shed some light on this? Thanks.
2007 Suzuki C50T
TonyC50T is offline
post #8 of 16 (permalink) Old 02-04-2017, 09:25 PM
GregWork's Avatar
Not the axle, but the drive shaft housing tube; three bolt holes need to be either enlarged a bit, or elongated. Enlarged is easy, just use a drill bit centered. Elongated is best if you want to revert back to stock drive.
My C90 drive install on C50T
rvcycleguy likes this.
2006 C50T Blvd
GregWork is offline
post #9 of 16 (permalink) Old 02-05-2017, 08:49 AM
rvcycleguy's Avatar
As shown in the picture, it's as if you had 9/16 bolt and needed to use 5/8th. Easy to do with a rat tail file, Dremel, etc.
2006 HD Road King FLCRCI
2010-Guanajuato, Mexico
89A-Sedona, Grand Canyon NP
CO Rocky Mtn. NP
2013/2014 Scenic 30A FL
2014/2015- Big Bend
2017- Santa Fe, Taos
rvcycleguy is offline
post #10 of 16 (permalink) Old 02-05-2017, 08:58 AM
Sleepwalker's Avatar
As stated already, one of the best mods you can do to your bike, IMHO.
I also bought one from Motiv, included everything I needed.
The talked about holes took less then 10 minutes to elongate.
My 2014 had about 4000 on it at the time, 50,000+ now.
Opens up a whole new riding experience for long slab runs, would never go back!
2014 C50T
Member of the Iron Horse Cavalry/ABATE of Virginia
"The more I learn, the more I realize I donít know."
ó Albert Einstein
Sleepwalker is offline
