#11 (permalink) |
Yes there are differences in Cast versus steel wheels. My M50 has cast wheels and the standard C50 spacer cut for the VS1400 drive I installed worked fine for me. But manufacturing tollerances sometimes will necessitate a slightly longer spacer in some instances.
#12 (permalink) |
It sounds simple but how long has it been since you changed the rear end fluid?
![]() Excuse me? Excuse me, senor? May I speak to you please? I asked for a mai tai, and they brought me a pina colada, and I said no salt, NO salt for the margarita, but it had salt on it, big grains of salt, floating in the glass... |
#13 (permalink) |
Fluid was changed when I installed the drive, so roughly 2 months or so.
![]() 05 C50- black wrapped VH Longshots, PCIII, blacked out air box/pair valve cover/headlight trim, John's 2.5" lowering bones, Mustang fender bib, Cruiser Performance 1.25" fatty T bars, naked front end, side mounted tag, Hamling drive |
#14 (permalink) |
I had something that sounds the same develop a few months and a few thousand miles after installing a drive from Aric. I searched the board and one of the suggestions was to check the torque on the axel nut and make sure it was at spec.
When I did it was not tight enough and when I torqued it with a torque wrench the sound went away. The setting is 47 ft lbs |
#15 (permalink) |
I have had a guy who purchased a drive from me have some spacer issues- needed slightly more thickness on the spacer- a washer fixed it-
