#11 (permalink) |
Most newer bikes are Nikasil plated cylinders.
You do not bore Nikasil plated cylinders!!!! You do not hone Nikasil plated cylinder, you just scuff them before putting in new rings (and pistons). The 90 and the 109 have Suzuki's proprietary version of the Nikasil called SCEM. I am not sure about the 50, but ALL of Suzuki's off-road bikes have Nikasil. I would be making **** sure you do not have Nikasil coated cylinder before going out and having them bored or else you'll be buying new cylinders!
Why use a big word when a diminutive utterance would suffice? |
#12 (permalink) |
Prolly cheaper to but a new jug...or a lower miles used.
Nikasil Cylinder Repair, Re-Nikasil and Cylinder plating |
#13 (permalink) | |
I don't have the money to get another bike new or used so a few hundred dollars for the top end is just an investment for a few more years of riding, my bike is an 08' and I have just shy of 44,000 miles (hard, fast miles) I ride my bike like I stole every day so it's been very dependable, just uses too much oil.
Good Times Happen On The Boulevard And The Boulevard Is Suzuki=========================================== In Dog Beers I've Only Had One... ----------------------------------------------------- "metal monsters that let us breathe. Let us smell. Keep us from being numb" -Zookoff |
#14 (permalink) | |
I was going to say if you can't figure out if they are Nikasil or not, take them to a machine shop that does Harley cylinders. Harley's are old school, low-tech, yesteryear machines and do not have Nikasil cylinders (maybe some of the new ones do). A shop that works on Harley cylinders can tell you what your C50's cylinders are and how much over-bore they can take.
#15 (permalink) |
I'm new to the site and my bike! And this is my first bike, I bought a 05 c50 and have done a little work to kinda make it different then others, I dropped It 2.5 inches, cobra pipes, new mirrors and levers also went with wide white walls, I love the bike just would like more power what if at all possible is the biggest piston I could go up to! I'd like to build the motor up over the winter! The bike will be apart for paint so figure try some motor work if possible... Any help would be great! Thanks
#16 (permalink) |
because of the engine being a water pumper the cylinders are sleeved and the sleeve is very thin, the biggest piston you can get is .5 mm oversize. Suzuki is the only one I've found, that will bump the engine size from an 805 to an 814 that wil make your C50 a C50.56 LOL
