C90 Final drive mod and install with pics - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 48 (permalink) Old 06-25-2012, 05:30 PM Thread Starter
Last summer the C90 drive blew a seal and oil all over my nice whitewalls
Since it was prime riding time, I popped the oem drive in and put the C90 drive in the "winter maintenance" lineup.
Changed the seal this winter and now it's time to reinstall on the bike, thought I'd include some pics.
I went to the trouble of installing the oem C90 driveshaft complete, as if it would be if someone recieved an unmodifed drive.
The decision then must be made, modify a C50 driveshaft, modify a C90 driveshaft, or modify a universal joint. Aric Balster can modify a C50 driveshaft by moving the shoulder back .200. DJHillis can do a cut, sleeve, reweld of a C90 driveshaft, or any competent machine shop can do either as well as modify a universal joint. I happen to have a Balster modded C50 shaft, so I'll use it.
Remove grease seal
Remove circlip (snapring)
Separate driveshaft from drive coupler. You will have drive with coupler, spring behind drive shaft, driveshaft, circlip, and grease seal.
I have laid out parts for reassembly.
Final drive (C90/VL1500 or VS1400)
Modified driveshaft (VL800/C50 with shoulder moved back .200 or C90 cut sleeved, rewelded or stock unmodified VL800/C50 if installing a modified U-joint.
C90 spring
New grease seal (p/n 09283-30026)
Moly 60 grease
Snapring (circlip) suzuki recommends NOT reusing a circlip, but I reuse 'em anyway.
You have another decision to make as far as spacer, bushing or a combination spacerbushing.
VL1500 and C90 drives use a larger axle than VL800/C50 so the axle hole must be matched to the smaller axle size. I have a bushing to do that I got from Aric Balster. 19.94mm O.D and 16.70 I.D. You will also need an axle spacer 2 7/8ths long. Some just cut 2mm off an oem spacer, or you can use a piece of tubing.
Some people use a spacer with a bushing already machined into the end of it. This is the type DJHillis provides.
My Balster bushing pushed into the C90 drive case. Reminder, the bushing is not necessary when using a VS1400 drive. Spacer yes, bushing no.
Before install the drive shaft into the final drive, liberaly grease splines with Honda Moly paste ***THIS IS A CRITICAL STEP***IT WILL PREVENT DRIVESHAFT SPLINE FAILURE***
Install C90 spring, driveshaft of choice, circlip and new grease seal (suzuki calls it an oil seal, but what do they know).
I have had these seals pop out on me, after install (I gently tap them in place with hammer and small drift), I drizzle alittle thread locker around the seam between the new seal and the coupler, seems to help hold it in place.
Ready for install
Prep bike for wheel/tire removeal and remove left side "fake swingarm"
Prep right side for wheel/tire/brake removeal
Remove wheel/brake assembly
Remove 3 cap nuts from oem final drive and remove final drive from swingarm
Decision time again. The new final drive bolt pattern is just slightly larger than the oem pattern. You have two options, you can drill all three holes oversize using a 9/16ths drill bit or step bit, or you can simply file the holes oblong with a rat tail file. Filing removes alittle less material, drilling probably goes faster. Either way will work. If you drill you may need bushings if you ever want to reinstall you oem drive. I filed my holes with an air die grinder.
I removed the paint from from the area that needed to be ground out and used the C90 bearing plate (metal gasket) as a pattern to show me where to remove metal by filing.
Don't forget (like I did) to grease the u-joint end of the driveshaft and install the unit onto the swingarm, make sure there is a "bearing plate" (metal gasket) between the final drive case and swingarm mount flange. I had to remove mine and add the moly grease and was very very lucky, one stab each time and the driveshaft spines engaged the u-joint perfect. It is rare when that happens for me, I usually have to use a broom handle to reposition the u-joint. Tighten the mount nuts.
Make sure axle spacer is intalled in final drive
This is a good time to fill with 90 weight gear oil while the tire/wheel are not in the way
Reinstall wheel/brake assembly. I use a platform scissors jack to raise the wheel up to the final drive.
Reinstall brake assembly, adjust as necessary, torque wheel nut, install cotter pin (I was all out so I have a tempary hitch pin in there.
Anytime I do any rear wheel work I always have to finish up with alittle Wesley's bleach white.
There you have it, a final drive mod and install. Hope the pics help, and as always feel free to ask any questions.
rhinorat likes this.
472viper is offline
The Following 9 Users Say Thank You to 472viper For This Useful Post:
Aboyassin2004 (12-21-2016), ArthurBNH (06-27-2012), c50man (09-20-2012), GregR (07-06-2012), MET-RICK (10-09-2013), Moto-Suzzi G50 (07-05-2012), PV458 (07-13-2013), WillygeeTX (01-19-2013), zfmrchnt (07-11-2012)
post #2 of 48 (permalink) Old 06-25-2012, 06:02 PM
BIGBIRD123's Avatar
Looks like your wife let you use her side of the garage.....nice write-up
_____________
2005 C50 R.I.P.
BIGBIRD123 is offline
post #3 of 48 (permalink) Old 06-25-2012, 06:12 PM
LeoinSA's Avatar
Yeah - what BB said!
Why is the garage so clean and neat? That's against the law!
"For the truth is that I already know as much about my fate as I need to.
The day will come when I die.
The only matter of consequence is what I will do with my allotted time?"
CRASHED! 2001 BMW 1150 GS - nicely farkled
2009 Boulevard C50 Special Edition - Given away to son
LeoinSA is offline
post #4 of 48 (permalink) Old 06-25-2012, 06:15 PM Thread Starter
I snuck this project in while she was at work.
472viper is offline
post #5 of 48 (permalink) Old 06-25-2012, 06:27 PM
W7WX's Avatar
X~4! How do you find anything in that place?
Thanks for the images and write up Viper...great job as usual!
____________________________________
2011 C50T w/DJ Drive & 2005 C90
ATGATT
W7WX is offline
post #6 of 48 (permalink) Old 06-25-2012, 07:15 PM
t-man403's Avatar
Nice!!
Almost makes me want to get another Volusia!
t-man403 is offline
post #7 of 48 (permalink) Old 06-25-2012, 09:10 PM
MoDZuKi's Avatar
Nice Viper- I Nominate for a sticky- This is nice and complete...
seconds???
MoDZuKi is offline
post #8 of 48 (permalink) Old 06-26-2012, 10:16 AM
Jmbrad's Avatar
Sticky? I'll second that nomination. YES!!!!!
2011 Vulcan Nomad 1700 (SOLD)
New to me 8/22/15 w/7k miles
03 Vol 1st Bike EVER!
New to me in 8/11 w/
16k miles
Jmbrad is offline
post #9 of 48 (permalink) Old 06-26-2012, 11:14 AM
t-man403's Avatar
I'm curious as to why you didn't use the lift table.
I'm thinking with the scissor jack on the table and the floor plate out, it would be a job done standing up. I know most don't have the table and I got rid of the bike lift in favor of the table.
t-man403 is offline
post #10 of 48 (permalink) Old 06-26-2012, 11:19 AM Thread Starter
The table works great for getting the bike up to a good working height, but the floor plate leaves alittle to be desired.
It's alittle combersome dropping that wheel and tire out of the floor plate, it just barely fits and it's a real PIA for a fat old fart like me to lift it back up in there.
With the bike lift I can pull the wheel tire and only have to drop it an inch or two, then lift the bike to clear the wheel/tire.
It's all about working smarter. (and being lazy)
472viper is offline
