C90 Final drive mod and install with pics - Page 5 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #41 of 48 (permalink) Old 08-16-2015, 06:09 PM Thread Starter
Originally Posted by cpurick View Post
And the gap we're talking about is housing to wheel?
Also, Viper, do you still believe shortening the u-joint is the way to go regarding shaft length? If you think machining the shoulder back (and taking down the tip) would be better I could go that way.
The preferred method for modifying the driveshaft would be to reposition the shoulder. The u-joint shortening was done when the person did not want to go the machinest route.
472viper is offline
post #42 of 48 (permalink) Old 02-12-2016, 09:21 PM
did u do anything on the larger hole in the 90 drive for the main bolt that goes through the center of it
joshmaggie is offline
post #43 of 48 (permalink) Old 02-12-2016, 09:24 PM
so on the bolt that goes through it all did u do anything on size since 90 has larger hole
post #44 of 48 (permalink) Old 02-13-2016, 12:06 AM
RiderRon's Avatar
joshmaggie, first of all welcome!! A bushing can be pressed into the bushing that is already in the drive for the axle bolt to fit the 1500 drive or you can have a combination spacer/bushing made. The dimensions for the bushing are in the sticky link below. the bushing length is 3/4" long. Search through the thread, there are guys on here that sells the parts you need.
Drawing for C90 Drive Mod Check
RiderRon is offline
post #45 of 48 (permalink) Old 02-13-2016, 03:24 PM
What exhaust pipe is that on your bike. Been looking at putting on a 2 into 1
Tim
Cowboy126th is offline
post #46 of 48 (permalink) Old 12-21-2016, 09:11 AM
Please Provide more details
Dear Viper
Thank you very much for the awesome info and know-how.
I'd just like to have some more details from you regarding the same. As I'm not in the US and need to do the MOD.
What are the measurements to modify the C90 shaft? and the lenth of the spacer and the bushing?
Kindly advise.
Thanks again
Aboyassin2004 is offline
post #47 of 48 (permalink) Old 12-21-2016, 04:57 PM
Originally Posted by Aboyassin2004 View Post
Dear Viper
Kindly advise.
Thanks again
Viper is very helpful and knowledgable. PM him as I don't think he's unapproachable.
post #48 of 48 (permalink) Old 12-22-2016, 08:55 AM
The new member needs to make four more posts, (for a total of five) in order to use the private message system.
Also, below here's some links to threads with prints and specs for bushing & driveshaft mods for the DJ Drive.
Correct drawing for Driveshaft machining-**updates and new drawing**
