C90 Final drive mod and install with pics - Page 3 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #21 of 48 (permalink) Old 06-27-2012, 06:23 PM Thread Starter
Yup, and all the shorter one will do for you is close the gap alittle between the final drive case and the wheel hub.
The hope is that it doesn't close it so much that the hub rubs on the backing plate bolts.
Take alook at your bearing when you have the wheel off.
If it's flush with the hub, I'd try the shorter spacer, if it looks like it's pushed alittle deeper than the edge of the hub, the longer spacer may be in order.
472viper is offline
post #22 of 48 (permalink) Old 06-28-2012, 01:07 PM
Aric had the approprate lenght spacer for the case wheels. He is sending it out today.
13 V-strom 650
08 C50 LE *Sold*
TravisM is offline
post #23 of 48 (permalink) Old 06-28-2012, 02:48 PM Thread Starter
Hey can you get me a measurement on it?
And I don't know if they are all gonna be the same.
I am using the same spacer with my cast wheels as I used with my spoke wheels, and I think the variance is in the depth at which the left side bearing is pressed.
472viper is offline
post #24 of 48 (permalink) Old 06-28-2012, 03:07 PM
MoDZuKi's Avatar
I took 2mm off the VS1400 bushing that came with my drive - on my M50 it worked fine.. no rubbing --cast wheels
MoDZuKi is offline
post #25 of 48 (permalink) Old 06-28-2012, 03:25 PM
I'll get the measurements as soon as I have it in hand.
13 V-strom 650
08 C50 LE *Sold*
TravisM is offline
The Following User Says Thank You to TravisM For This Useful Post:
472viper (06-28-2012)
post #26 of 48 (permalink) Old 07-02-2012, 06:00 PM
The spacer I received is 2 15/16" according to my tape measurer. For reference, that same rule measures ~3 1/16 for the stock part. Since it is metric this doesn't line up exactly. However, the unit from Aric does. If you want pictures of the two side by side I can take them tonight.
13 V-strom 650
08 C50 LE *Sold*
TravisM is offline
post #27 of 48 (permalink) Old 07-02-2012, 06:04 PM Thread Starter
No, that's fine.
Sounds like Aric is allowing an added 1/16th inch for cast wheels.
472viper is offline
post #28 of 48 (permalink) Old 07-06-2012, 09:55 AM Thread Starter
Hey I see this thread recieved a sticky, just want to say thanks.
472viper is offline
post #29 of 48 (permalink) Old 07-06-2012, 10:53 AM
Moto-Suzzi G50's Avatar
No...Thank you Viper. Job well done. I hope to be installing the mod very soon. I have already learned tons from this forum. I am not at the point where I can contribute much but pretty soon I should be able to put together an...."Expensive lessons learned on things not to do to your Suzuki".... and "Things not to do around or above your your Suzuki while parked in your garage".
Cheers and have a great weekend!
Moto-Suzzi G50 is offline
post #30 of 48 (permalink) Old 07-06-2012, 11:19 AM
MoDZuKi's Avatar
and..........
***Caution- Reading posts on this forum may contribute to contagion of the dreaded Moditis Virus!***
If affected with this virus- Contact EBAY, Kuryakyn, or fellow VR members for a treatment and help with symptons as there IS NO CURE!
MoDZuKi is offline
