Contact info for Final Drive Modification - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #11 of 34 (permalink) Old 02-08-2012, 08:26 PM Thread Starter
From what I hear, Dan has alot of irons in the fire, so one does have to be patient.
As has been said,
1) Dan modifies C90/VL1500 and VS1400 driveshafts. This leaves your oem drive intact, ready for reuse.
2) Aric modifies C50/VL800 driveshafts to be used in the above mentioned drives.
3) Both guys can modify the drive case to accept the fake swingarm.
4) The fake swingarm can be modified to fit on the above drives. The advantage of this is it saves on shipping costs, it's alot cheaper to ship a driveshaft for modification than it is the entire drive unit.
Any "preferred" method is simply personal preference. They both do great work and I've had both driveshafts.
If I had a C90/VL1500/VS1400 driveshaft, I'd send it to Dan and mod my own swingarm and not have the drivecase machined.
If I had a C50 driveshaft and a 90/1500/1400 drive without a driveshaft, I'd send it off to Aric and have the C50 shaft modded by him.
Both guys can provide you the proper spacer or spacer/bushing according to which drive you have.
472viper is offline
zfmrchnt (02-08-2012)
post #12 of 34 (permalink) Old 02-08-2012, 08:27 PM Thread Starter
Originally Posted by tidcab View Post
Where are these guys located?
Dan lives in Ohio and Aric lives in Sturgis SoDak.
472viper is offline
post #13 of 34 (permalink) Old 02-08-2012, 08:37 PM
When I was at Dan's house, he has a full shop in his garage, where he does the drive work. His day job is in the next town over. I dropped the drive off on a Saturday. My visit was short due to his being needed to provide mechanic service to someone. Yep, the guy is busy.
yogurt is offline
post #14 of 34 (permalink) Old 02-08-2012, 09:58 PM
tidcab's Avatar
I must've missed something? In doing this mod whats up with a fake swingarm?
tidcab is offline
post #15 of 34 (permalink) Old 02-09-2012, 11:58 AM
I guess if you want to reuse the swing arm on the new drive, you can either grind some material off the inside of the swing arm, or remove some metal from the case, which Dan is going to do for me. It is not cheap, going that route, but I am lazy. The shape of the case on the 1400/1500 drive is different, so the swing arm won't just bolt back on, if you wish to use it. Other members have stated that the swing arm provides NO structural rigidity, it is just for styling.
yogurt is offline
post #16 of 34 (permalink) Old 02-09-2012, 12:02 PM Thread Starter
^^^Truth^^^
"Fake swingarm" is a term that is used for the piece on the left side that bolts to the final drive after it has been installed on "real" swingarm. It's only purpose is to give the look of assymetry to the swingarm, making the left side look like the right side. It serves no structual purpose.
472viper is offline
post #17 of 34 (permalink) Old 02-17-2012, 09:07 PM
dabo0652's Avatar
Dan Hillis Email
Dan Hillis's original email address is not working. I've been contacting him here:
hillisfabrication@gmail.com
I know it works, just got my DJ drive today, will install next week, can't wait.
dabo0652 is offline
post #18 of 34 (permalink) Old 03-23-2012, 03:26 PM
anyone have info on where I can get my hands on a final drive so I can do the conversion?
Gizmo327 is offline
post #19 of 34 (permalink) Old 03-23-2012, 04:09 PM
BIGBIRD123's Avatar
eBay...
_____________
2005 C50 R.I.P.
BIGBIRD123 is offline
post #20 of 34 (permalink) Old 04-08-2012, 06:20 PM
4d
4d's Avatar
So what ever one is say if I had a c90 final drive I can install it with no mod at all (if I didn't want the fake swing arm). And just send in a C50 drive shaft to have it moded...Yes.
I'm working on being politically correct. But its going take a VERY VERY LONG TIME
4d is offline
