My speedo recently went further south than I have gone. So when I replaced it, I took a couple of pictures for those that haven't had the pleasure of not knowing how fast you are going. This is on a 2002 Vol.
I jacked the bike up to where there was just a slight drag of friction with the tire to the ground. I did not have to completely remove the wheel, there is enough room to replace the speedo sensor if that is all you have to do. Here is what the sensor looks like (new). The 4 tabs you see are what breaks off and it will no longer catch the tabs that are part of the hub. Thus it won't spin and will not give you a speed indication. ![]() Next is to remove the pinch bolt, the axle, and spacer. ![]() ![]() (facing the bike from the front) Lean the wheel to the right, and you can pull the speedo sensor from the hub. Remove the old broken sensor, grease up the new one. I used the 60 moly grease. And then carefully put the new sensor in. ![]() When mounting the sensor back to the hub, make sure that the tabs are going between the tabs that are part of the hub. This is where most are broken because when folks replace the wheel they do not pay attention to where the tabs are oriented in relationship to the hub tabs. You also want to make sure the locking slot on the back of the speedo housing (fork side) is secured to the small post on the fork. With that done it's pretty much reverse order to get the wheel back together. Slide the wheel back to the right, put the spacer in, put your axle back in and torque to recommended specs ( I think it's 48 ft/lbs). The manual then recommends that you excersize the front forks before tightening the pinch bolt. I dropped the bike back on the ground and compressed the forks by pushing down on the handlebars. Then replace the pinch bolt and tighten to recommended specs ( I think it's 24 ft/lbs). Go for a test ride, unless you had maintenance hops during the procedure. Hope this helps someone.
Ever notice some people are so narrow minded that their ears rub together? Last edited by kawesttex; 04-03-2011 at 03:36 PM. Reason: Title clarafication |
| The Following 20 Users Say Thank You to kawesttex For This Useful Post: | 1SG Davo (04-28-2011), bill825 (07-01-2012), Boxwrench (06-07-2011), cavie (09-21-2011), chuckdilmore (09-02-2011), Circles (07-18-2011), dcat-1831 (03-11-2012), Foxtail207 (04-03-2011), GaMedic (04-17-2012), hyder124 (12-22-2011), krob63 (09-04-2011), Kyleh1214 (02-15-2013), mochanic (04-03-2011), MoDZuKi (03-10-2012), Pipeman45 (09-03-2011), redboul (04-05-2011), RemingtonNY (12-21-2011), Renfield54 (06-07-2011), Rips241 (07-18-2011), t-man403 (04-03-2011) |
This is going to be useful for me. This is new tire week!
Thanks for the post and pics!
Okay, it's the way it seems it always goes!
Took the front wheel off and this is what I got. The broken tabs you see ^ here, are from here v. I'm hoping this is common enough that the parts will be in stock.
"Men are like steel, when they lose their temper, they lose their worth." C. Norris ![]() 98' VALKYRIE __________________________ 02' VOLUSIA Last edited by t-man403; 04-05-2011 at 10:25 AM. |
Yep, that's what I found. I ordered mine online at onieda suzuki and got them in 3 days, no local dealer. Just make sure you grease it up before reinstalling.
Good pictures to go with mine. You had your wheel all the way off so it was easier to get those views.
Ever notice some people are so narrow minded that their ears rub together? |
#5 (permalink) |
Thanks Kawesttex, Great job on the pics. Very helpful. "Needs to added as a sticky"
![]() Never rub another mans rhubarb! Last edited by redboul; 04-05-2011 at 07:28 AM. |
#7 (permalink) |
Agreed... Keep that thing greased.
I was having an intermittent squeeking sound during a cold snap and couldn't locate it. I took the rear drive out, lubed the splines, checked the bearings. I then took the front tire off and checked the bearings. Checked all of the brakes front and back... Nothing. Then I checked the speedo sensor and found it dry. After a little grease, the sqeek never came back. Edmo
Embrace the Automation.... |
| The Following User Says Thank You to Edmo For This Useful Post: | baxtc1 (05-14-2012) |
#8 (permalink) |
Any issues with riding the bike till it gets fixed?
DavoFamily First, Always Southern Cruisers Riding Club SCRC Chap. 272 War isn't about those that are right.....it's only about those that are left. |
#9 (permalink) |
I have a ride this weekend and just lost my speedo, need to get it ordered but would not have it fixed before saturday
#10 (permalink) |
As you can see in the pics above every tooth was busted off of mine and the speedo still worked believe it or not! I have no idea how long it was like that and I'm assuming the previous owner my be the culprit for not putting it back together properly. It's pretty self explanatory looking at the parts how to do it.
| The Following User Says Thank You to t-man403 For This Useful Post: | Stelth01 (05-01-2011) |
