Speedo Sensor Replacement (with pictures) - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 3Likes
post #11 of 115 (permalink) Old 04-28-2011, 09:12 PM
10-64's Avatar
Originally Posted by 1SG Davo View Post
Any issues with riding the bike till it gets fixed?
Do you have a "GPS" Unit? You could always use that to determine your speed. (Just a thought)
I hate autocorrect. I always end up posting some thong I didn't Nintendo.
(BTW, In "Dog Beers", I've only had "2"!)
2015 Harley Davidson XG750 (Sold)
2010 Suzuki Boulevard C50T
2007 Kawasaki 250 KLS (Traded on C50T)
10-64 is offline
post #12 of 115 (permalink) Old 05-01-2011, 03:53 PM
1SG Davo's Avatar
Originally Posted by kawesttex View Post
My speedo recently went further south than I have gone. So when I replaced it, I took a couple of pictures for those that haven't had the pleasure of not knowing how fast you are going. This is on a 2002 Vol.
I jacked the bike up to where there was just a slight drag of friction with the tire to the ground. I did not have to completely remove the wheel, there is enough room to replace the speedo sensor if that is all you have to do.
Here is what the sensor looks like (new). The 4 tabs you see are what breaks off and it will no longer catch the tabs that are part of the hub. Thus it won't spin and will not give you a speed indication.
Next is to remove the pinch bolt, the axle, and spacer.
(facing the bike from the front) Lean the wheel to the right, and you can pull the speedo sensor from the hub. Remove the old broken sensor, grease up the new one. I used the 60 moly grease. And then carefully put the new sensor in.
When mounting the sensor back to the hub, make sure that the tabs are going between the tabs that are part of the hub. This is where most are broken because when folks replace the wheel they do not pay attention to where the tabs are oriented in relationship to the hub tabs. You also want to make sure the locking slot on the back of the speedo housing (fork side) is secured to the small post on the fork.
With that done it's pretty much reverse order to get the wheel back together. Slide the wheel back to the right, put the spacer in, put your axle back in and torque to recommended specs ( I think it's 48 ft/lbs). The manual then recommends that you excersize the front forks before tightening the pinch bolt. I dropped the bike back on the ground and compressed the forks by pushing down on the handlebars. Then replace the pinch bolt and tighten to recommended specs ( I think it's 24 ft/lbs). Go for a test ride, unless you had maintenance hops during the procedure.
Hope this helps someone.
Is their a part number or name for this so that I can order it online?
Davo
Family First, Always
Southern Cruisers Riding Club
SCRC Chap. 272
War isn't about those that are right.....it's only about those that are left.
1SG Davo is offline
post #13 of 115 (permalink) Old 05-01-2011, 05:09 PM
Jendesigner's Avatar
Speedo sensor
2001-04 MAGNET 34983-21E00
2005-08 MAGNET 34983-27G00
Jen / "All leather, no lace"
2000 Nomad 1500 | 2003 Volusia | 2014 Stryker
Jendesigner is offline
The Following 2 Users Say Thank You to Jendesigner For This Useful Post:
Circles (07-18-2011), Pipeman45 (09-03-2011)
post #14 of 115 (permalink) Old 05-02-2011, 01:03 AM
t-man403's Avatar
There is a seal as well.
Part#09286-4401
t-man403 is offline
The Following User Says Thank You to t-man403 For This Useful Post:
post #15 of 115 (permalink) Old 05-03-2011, 02:15 PM
1SG Davo's Avatar
Thanks a million. Dave
Davo
SCRC Chap. 272
1SG Davo is offline
post #16 of 115 (permalink) Old 05-03-2011, 05:49 PM
Thanks for the pics and info.
Cheers
2511fj is offline
post #17 of 115 (permalink) Old 05-15-2011, 02:24 PM
1SG Davo's Avatar
just fixed mine, worked and went just as you said. No seal that I found though. Could not find the part on line for the seal as well. you would think that they would make something a little stronger for something that is moving as much as this part is.
Davo
SCRC Chap. 272
1SG Davo is offline
post #18 of 115 (permalink) Old 06-07-2011, 05:36 AM
Just ordered the sensor and seal today. Speedo stopped working a week after I got the bike. This will be the first thing I have to do. Hopefully its not to difficult.
acenitaly is offline
post #19 of 115 (permalink) Old 07-18-2011, 06:24 PM
Circles's Avatar
My speedo went south yesterday. No speed, no miles, just the clock working so I am suspecting my issue is the topic of this thread.
I am far from a mechanic but I think I can replace this magnet on my own. My question is about what I colored in red. How do I torque and measure the torque? Don't laugh guys, I seriously don't know what the term means and I have to get my bike repaired, heading for the Smokies on the 27th.
Thanks!
'03 Pearl White 40th Anniversary Edition Volusia -"Starlet"
Metzler 880's, J&M CB 2003 Radio, Vicking bags, Scootworks 4" PhatRisers, Grasshopper LTD drivers backrest, Mean City Cycles stock seat re-do, Memphis Shades Windshield & Lowers
Circles is offline
post #20 of 115 (permalink) Old 07-18-2011, 06:38 PM
Boxwrench's Avatar
Thanks!
Borrow a torque wrench from someone/shop that is in foot pounds and has the 48# in the mid range.
Also don't drop it or bounce the wrench when tightening....use a steady pressure till it goes "click" or the proper amount is indicated.
Boxwrench is offline
The Following User Says Thank You to Boxwrench For This Useful Post:
