Drawing for C90 Drive Mod Check - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 47 (permalink) Old 11-30-2010, 02:48 PM Thread Starter
I have been reading a lot about the Mod of adding a C90 drive to a C50.
A lot of threads to read and go thought but I think I got all the info to make drawing of the parts that need to be modified or made. I'm going to post the drawing and see if any of you Volusia riders would double check me on my drawings.
One drawing is of the shaft mod.
One is of the Bushing.
One is of the spacer.
Silver/White C50
Driving light 150W, 4" Risers
Lower Stock Mirriors, Custom Cruising Switch
Custom Intake, GMan Bully FI Controller
De-Paired, Custom Rear Light layout
Drill out Stock Pipes, Lower 2-1/2"
Silver Buffalo Rider
Silver Buffalo Rider is offline
The Following 2 Users Say Thank You to Silver Buffalo Rider For This Useful Post:
BullyVarder (09-22-2011), imagineer (10-06-2011)
post #2 of 47 (permalink) Old 11-30-2010, 03:37 PM
rvcycleguy's Avatar
I see your in the Houston area. I can recommend a Suzuki riders group that offers rides for the surrounding areas as well as to the Hill Country.
2006 HD Road King FLCRCI
2010-Guanajuato, Mexico
89A-Sedona, Grand Canyon NP
rvcycleguy is offline
post #3 of 47 (permalink) Old 11-30-2010, 04:17 PM
v0lusia's Avatar
Moved to Motors, Transmissions & Drives
-Twisties give me happy pants
v0lusia is offline
post #4 of 47 (permalink) Old 11-30-2010, 05:22 PM
Fodder4U's Avatar
DOH and here I though there was a raffle for the mod and came in to sign up lol.
Mark
2009 Gray and Silver C50 SE: MS Batwing, DJ Drive, Cobra bars, Chrome Stebel Horn and more to come...
Album
Fodder4U is offline
post #5 of 47 (permalink) Old 12-01-2010, 01:14 AM
Those all look pretty good to me. The C90 drive bolt pattern for mating to the swing arm has a larger circumerance than the C50 bolt pattern. There are two methods for accomodating this. One is to drill the original bolt holes oversize to 9/16ths inch. The other method is to "slot" or elongate each hole with a file to accept a larger diameter bolt pattern. This link contains an excellant drawing of elongated holes.
IntruderAlert Cafe
Great drawings btw, those should be stickied, I'll look into it.
472viper is offline
Aboyassin2004 (12-21-2016)
post #6 of 47 (permalink) Old 12-01-2010, 02:38 PM Thread Starter
I did not draw the bolt patten out because I had already seen this drawing on a earlier thread.
Silver/White C50
post #7 of 47 (permalink) Old 12-02-2010, 02:15 AM
Ok, well this thread has been stickied in the Motors Drives and Transmissions, so your pdf's and the bolt pattern thread will be easily accessible without having to do a search. Thanks.
472viper is offline
post #8 of 47 (permalink) Old 04-13-2011, 09:44 AM
i have just discovered this thread. I have an 06 M50, what year C90 should I be looking for?
thanx
MasterTechie is offline
post #9 of 47 (permalink) Old 04-13-2011, 10:05 AM
Any year C90, VL1500 or VS1400.
There are a couple of riders who have even used GV1400 (the old Cavalcade) but that mod is a little different in that the result is a rear wheel that is slightly offset from the front (like a "dog tracking" condition) and one cannot install the cotter pin in the axle bolt.
If using a VS1400 drive you do not need the bushing as the VS1400 drive uses an axle the same diameter as the C50, however the VS1400 driveshaft is much shorter so the pdf drawing supplied in this thread does not apply. There is an alternate method for any of these drives to modify a C50 or VL800 driveshaft.
472viper is offline
post #10 of 47 (permalink) Old 10-06-2011, 01:27 PM
I'm looking forthe correct size for the bushing for the c90 drive casing it shows inside and outside but not how thick,Thanks
IF AT FIRST YOU DON'T SUCCEED THEN BY ALL MEANS(GO FOR A RIDE)
drcreek56 is offline
