Drawing for C90 Drive Mod Check - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #11 of 47 (permalink) Old 10-06-2011, 01:52 PM
indyrob's Avatar
Originally Posted by Fodder4U View Post
DOH and here I though there was a raffle for the mod and came in to sign up lol.
LOL...Yeah, me too until I clicked on the thead to find out how to enter the drawing!
2003 Volusia (Aug 11)
Added: bigger saddlebags, passenger BR, VC throttle lock, VA Lowers, CYFHMN Club w/BikerPop SSS Bracket, ME880 WWW, 14" ape's, ISO grips, DJ Drive Member, Cobra Highway bar with footpegs, EasyBrackets
Wants: Studded Mustang Seat, lightbar, ect.....
indyrob is offline
post #12 of 47 (permalink) Old 10-06-2011, 02:46 PM
Jendesigner's Avatar
Originally Posted by drcreek56 View Post
I'm looking forthe correct size for the bushing for the c90 drive casing it shows inside and outside but not how thick,Thanks
I may be wrong but I took the two numbers you know already which is the outside number and subtracted the inside number and then divided by 2 which makes the bushing .061 thick.
Jen / "All leather, no lace"
2000 Nomad 1500 | 2003 Volusia | 2014 Stryker
Jendesigner is offline
post #13 of 47 (permalink) Old 10-06-2011, 03:20 PM
Yup, that's how it's done.
472viper is offline
post #14 of 47 (permalink) Old 10-06-2011, 05:09 PM
Man you guys dont know what I need, I know how thick that spacer is what is it for ang how long does it have to be. I know how long the spacer is 2 /7/8 long what is the bushing for I am lost now I have read the threads you need a spacer and a bushing for the c90 conversion,Thanks for your help.
IF AT FIRST YOU DON'T SUCCEED THEN BY ALL MEANS(GO FOR A RIDE)
drcreek56 is offline
post #15 of 47 (permalink) Old 10-06-2011, 05:35 PM
The only bushings I got when doing the drive was to insert in the holes after they were drilled if I wanted to put the old drive back in. Viper can give you all the details, pm him if I got the question wrong.
post #16 of 47 (permalink) Old 10-06-2011, 05:54 PM
At the beginning of this thread there is some drawings from silver Buf the three drawing are the shaft bushing and the spacer what is the bushing for I have the axle spacer made allready not sure about the bushing in the drawing is for?
post #17 of 47 (permalink) Old 10-06-2011, 06:10 PM
LOL, that bushing is .75 inch long.
I tell you, there is some tolerance to all those dimensions. It is best to take the drive case and the axle to a machinest and have him bush the case for the axle. He'll know what and how to do it. If you don't have an axle in hand, still take the drive case to the machinest, tell him you need to bush the case to accept an axle with a diameter of .6654. He'll know what to do.
472viper is offline
drcreek56 (10-06-2011)
post #18 of 47 (permalink) Old 10-06-2011, 07:59 PM
Now we are getting somewhere thank you very much now I know that the axle is larger on the c50 so you need to bush it for the axle,but what is the 3/4 bushing for Im sure I will find out when I go put it back together but I would like to know a little sooner LOL, and by the thanks for your help plan to convert on next tuesday.
post #19 of 47 (permalink) Old 10-06-2011, 08:26 PM
The C90 axle is larger than the C50 axle, therefor the axle hole in the C90 drive case is too large for the C50 axle.
A machinest can machine a bushing to press into the C90 drive case and that bushing will have a hole the same size as the C50 axle.
What it amounts to is that the O.D of the bushing is the same size as the O.D. of a C90 axle and the I.D. is the same size as the O.D. of a C50 axle. The bushing itself is .75 inch in lenth.
472viper is offline
post #20 of 47 (permalink) Old 06-21-2012, 01:43 PM
Does the drive shaft drawing in this thread apply to the VL1500 drive shaft as well?
TravisM is offline
