Clutch Plate/Spring Replacement DIY - Page 2 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #11 of 29 (permalink) Old 05-19-2009, 04:15 PM Thread Starter
Jim2005's Avatar
Originally Posted by wehrd1
are all the bolts that hold the clutch cover in place the same size/length?
I know when we did my Marauder clutch spring replacement, the bolts that held the chrome engine/clutch cover on were 2 diff. lengths, and HAD to be replaced in the same holes.
Thankfully I had read up on it, and was given a quick hint that before removing the new gasket from the package, take a sharpie and trace the gasket on the pkg. cardboard, and when removing the bolts from the clutch cover, insert them in the cardboard in the same holes you removed them from the cover. That way, you'll be sure to put the same bolts back in the same holes.
good pictorial. Thanks!
ya keep track of were the bolts for the cover came from.
295th
Jim2005 is offline
post #12 of 29 (permalink) Old 04-03-2011, 01:46 PM
wehrd1's Avatar
what do you torque the cover bolts back to?? what pounds? i don't think we have an inch torque wrench, just one in lbs. NEVERMIND...I found it in the pdf file. 7#
HEY!! mods, could you please STICKY this thread??
thanks
MY GALLERY
wehrd1 is offline
post #13 of 29 (permalink) Old 04-03-2011, 02:00 PM
wehrd1's Avatar
here's the detailed pdf file
http://www.dets.com/rusks/Volusia%20...eplacement.pdf
MY GALLERY
wehrd1 is offline
post #14 of 29 (permalink) Old 04-03-2011, 02:33 PM
Done!
Wood Welder is offline
post #15 of 29 (permalink) Old 07-03-2011, 10:45 AM
Clutch parts
Great post do you have any info on tourqe specs on the bolts, cover and spring bolts, also did you use oem springs and clutch plates or are there better after market parts. I have the DJ drive and I have to slip the clutch a bit when riding 2 up, as a result I have a flat spot when I let the clutch out so I will be doing this mod this winter.
Thanks for any info
cvc42 is offline
post #16 of 29 (permalink) Old 07-03-2011, 11:08 AM
Boxwrench's Avatar
Barnett plates and springs.
Boxwrench is offline
post #17 of 29 (permalink) Old 07-03-2011, 07:48 PM
I was just looking at Barnet they also have some competition clutch kits, a little heavier or would the normal replacement kits be enough ya think
cvc42 is offline
post #18 of 29 (permalink) Old 07-03-2011, 08:16 PM
Boxwrench's Avatar
It is my understanding that the standard Barnett springs exceed OEM.
post #19 of 29 (permalink) Old 09-06-2011, 12:52 PM
I just wanted to thank the guys who put this thread together. I just did the clutch on my 2005 C50 and it was the easiest thing you could do following your instructions. I did use the barnett kit which i found for around 130$ and it works great. The springs do feel slightly stiffer at the clutch lever and it engages nicely.
2005 C50
Bsnilloc is offline
post #20 of 29 (permalink) Old 10-07-2011, 12:23 AM
LkwdC50B's Avatar
Glad I saw this one, the pics don't make the process look as imposing as I feared it will be. Noticing a bit of clutch slippage recently when I really hammer the throttle getting on the freeway. Thanks for the step-by-step!
Matt
Why do some people expect an answer to a rhetorical question?
LkwdC50B is offline
