The DJ Drive mod explained - Page 3 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 7Likes
post #21 of 81 (permalink) Old 12-22-2011, 06:07 PM
Greetings,
I just bought a C90 drive, will receive in about 1-1/2 weeks. Could anyone post the email addresses of Hillis and Aric so I can get prices for a complete conversion, ready to bolt in? I would want to get a price also for the alteration necessary for using the fake swingarm. Thanks for any assistance. You can either post here or send me the info at markc1949@gmail.com.
yogurt is offline
post #22 of 81 (permalink) Old 12-22-2011, 09:07 PM Thread Starter
Last I heard Dan's website is down. This is the only contact info I have.
Phone 419 656 5347
Dan's got alot of irons in the fire, the trick is to just keep trying.
Aric can be reached via e-mail cuttec1@gmail.com
472viper is offline
post #23 of 81 (permalink) Old 12-23-2011, 07:15 PM
Thanks a bunch, viper. I'll get in touch with them when I get home. Appreciate it.
yogurt is offline
post #24 of 81 (permalink) Old 03-19-2012, 02:31 PM
So, does this all mean that a taller gears are not available - or prohibitively expensive? Or is it that this mod is easier than swapping out gears?
Also, if someone were to buy a one of the rears mentioned above, would it be possible to just swap those gears into the C50 rear case?
one_raven is offline
post #25 of 81 (permalink) Old 03-19-2012, 05:00 PM Thread Starter
The gears from a C90 will not fit in a C50 drive housing, they are physically too large.
DJ Hillis originaly looked into having a different gearset cut, and unless he wanted to buy like 5000 sets, the costs was not worth it.
472viper is offline
post #26 of 81 (permalink) Old 03-20-2012, 11:31 AM
Thanks!
post #27 of 81 (permalink) Old 04-11-2012, 09:14 AM
FutureE9's Avatar
Great write up Viper.... Thanks! Could you tell me if you could just modify a VS1400 Intruder Drive-shaft to fit the C50? I have a 2008 C50 and would love to have this done! (about 100 miles of Hwy driving to work) I've seen VS1400 Intruder S83 Final drive assembly's on E-Bay, but I'm not really sure what i'm looking for.
2008 C50 - Silver/Black with:
21" Memphis Fats, gradient black, shield,
Chrome VA Lowers,
really large UNIK Saddlebags (Now bolted on) (Thanks to Imagineer),
MAPAM ''S" radiator cover
Cobra highway bars,
Mustang seat
Lonnie's backrest
VS1400 Drive (Thanks to BigBird123!)
Driven with USAF pride!
FutureE9 is offline
post #28 of 81 (permalink) Old 04-11-2012, 09:53 AM Thread Starter
Yes, the 1400 driveshaft can be modified. It is quite abit too short, but one of the modifiers, DJ Hillis does lenthen and balance that driveshaft.
472viper is offline
FutureE9 (04-11-2012)
post #29 of 81 (permalink) Old 04-11-2012, 09:59 AM Thread Starter
There is a new way to skin the same old cat, it involves trimming 3/16ths of an inch off the engine side of the u-joint and then use a stock, unmodified C50/VL800 driveshaft.
VR member BIGBIRD has done it and it seems to be working. I am pretty convinced that it will cause no problems.
The upside is that the only machining modification is a simple trimming of the u-joint.
The downside is that removing the u-joint is alittle labor intensive, but not all that bad.
You can read about it here. 1500 drive mod
rhinorat likes this.
472viper is offline
post #30 of 81 (permalink) Old 03-17-2013, 11:37 PM
Final Drive compatibility
I found a 1991 VS 1400 final drive. Is this going to be a fit for a 2002 Volusia 800. Of course, I know about some potential issues like mounting holes need to be open up the drive shaft needs to be modified. I just want to make sure it is a basic fit.
Thanks
Samuki
Samuki
Admins:
IP does not ping correctly, and email seems to be bogus.......request sent for verification
psyc0
samuki is offline
