FREE - Perfect your clutch, with manual page... - Page 14 - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 3Likes
post #131 of 134 (permalink) Old 02-01-2015, 11:29 PM
FPS
FPS's Avatar
That's exaclty it. Thank you. Confirms I was doing it right and have a ligitimate issue.
Originally Posted by kydragonrider
I've owned my 2006 C50T for a year now and was totally satisfied with it until I joined this site.
Originally Posted by rodie1200 View Post
It's not what you ride, but if your wife will let you ride
FPS is offline
post #132 of 134 (permalink) Old 02-02-2015, 12:01 AM
Sleepwalker's Avatar
Hope it all works out, glad i was able to help a bit.
2014 C50T
Member of the Iron Horse Cavalry/ABATE of Virginia
"The more I learn, the more I realize I donít know."
ó Albert Einstein
Sleepwalker is offline
post #133 of 134 (permalink) Old 06-01-2015, 11:27 PM
daprez1963's Avatar
quick question...so I replaced my clutch springs and plates...having to remove exhaust pipes, covers etc...did the job with ease...replaced everything, filled back up with oil...adjusted cable etc...then took for ride...runs nice...but...
I had not noticed this before but now I hear a slight sound occasionally while in gear going down street...it sounds like keys jingling...it is coming from the same side of the clutch basket...I can't make out exactly where because its not constant...I have double checked all bolts and nothing is loose, no rattling due to vibration...I can not figure out what it is but since I had just done clutch, I am concerned I didn't do something right or didnt tighten springs enough or left my watch in the clutch assembly....
Does anyone have any clue what that noise might be...right side middle bike sounds like keys and is not contant...thanks
daprez1963 is offline
post #134 of 134 (permalink) Old 07-23-2016, 11:22 PM
Wow, thanks IronMan.
I had a slight slip that I noticed starting on the 03 vl800 I'm working on. Took all the side covers off and followed your advice. Cleaned and lubed any and everything---even washed out grime that had been hidden under half the bike.
Test drove after adjustment and later made a further tweak. Test drove again and discovered everything remarkably smooth, with no slip at all. Major difference in shifting resistance and noise. Buttoned it back up--good to go!
gemicka1 is offline
