Different rear drive ratio/highway cruising - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
 5Likes
post #1 of 2183 (permalink) Old 06-20-2007, 02:39 AM Thread Starter
Hey, I am new to this site. I just bought an 06' C50T and my fiance and I love it. I have previous experience with an 82' Kawasaki 750 and a 98' Honda Valkyrie (fathers).
I absolutely love everything about this bike except one thing, the highway cruising RPM's. I commute 124 miles a day and love using the bike for the fun factor and fuel mileage. Most of my commute is between 60-75MPH, which is in the 3700-4700 RPM range.
I have been considering different methods to lower cruising RPM's, specifically a taller rear tire/rim or different rear drive gears.
My specific requirements are a happy medium at highway speeds. Here are my opinions on what I may need to do this:
1)optimum efficiency is typically at max torque RPM, which in this case is 3500 RPM according to Suzuki.
2)I would like to run 65MPH (average of different cruising speeds/most highway speed limits) at 3500 RPM.
In order to accomplish this, I would need:
A)a 30" tire, compared to 26" stock tire. This is a 4" difference, which is unlikely to fit under the stock rear fender.
B)Final drive reduction of 3.00, rather than the stock 3.503.
Now my question's to all of you is this: Are you familiar with any company that manufactures different rear differential gears? Also, is there a different Suzuki (or other brand) gear that may fit the c50's rear diff housing that is closer to a 3:1 ratio.
If there is not a gear already manufactured, I may be in contact with a local high-performance manufacturing facility to see if they can manufacture a 3:1 rear drive gear.
Thanks,
Dan
Hillis Fabrication LLC
www.hillisfabrication.com
dhillis is offline
The Following 2 Users Say Thank You to dhillis For This Useful Post:
jkcerda (08-24-2013), Shloader (07-30-2012)
post #2 of 2183 (permalink) Old 06-20-2007, 03:28 AM Thread Starter
Update:
After some more research, I looked up the different gear ratios between the c50 and the c90. The c90 has a final drive ratio of 2.66:1, which would equal out to 3,082 RPMS at 65MPH on the c50.
I also looked up the online parts diagrams for the c50 and c90. According to the diagrams and part numbers, it appears as though the rear diff on both machines are quite similar. I may try get my hands on the c90's final driven gear and see if can be installed in the c50's case without modification.
Dan
dhillis is offline
post #3 of 2183 (permalink) Old 06-20-2007, 06:04 AM
Kinjin's Avatar
Keep us updated
-Knowledge is Power-
Kinjin is offline
post #4 of 2183 (permalink) Old 06-20-2007, 06:25 AM
First, welcome aboard!
Second, unless you are a bonafide gearhead I wouldn't do that. Besides the hassle (unless you are a tinkerer) the bike needs that ratio for roll on power at cruising speed. Hook that tall gear to that 50 cubic in. motor and you'll be kicking it down a gear just to change lanes. The VL800 just is what it is, an 805cc bike. I personally think the Suzuki engineers got the most out of it with the OEM set up. And it don't hurt it to wind it up because it takes a lickin' and keeps on tickin'.
That said, if you are hell-bent on doing this I will be following your progress with much interest! Good luck!
big ed is offline
post #5 of 2183 (permalink) Old 06-20-2007, 06:28 AM
Going from a 3.503 final drive ratio to a 2.66:1, aren't you concerned your going to have to push it to get it rolling? The bottem end would really suck. I don't think the bike revs high at all at 65-70. That's it's sweet spot. It's 75 and on up that things get a little buzzy.
Viper
472viper is offline
post #6 of 2183 (permalink) Old 06-20-2007, 06:57 AM Thread Starter
Let's just say I am a gearhead and a tinkerer beyond tinkering
Anyway, I am well aware of what it will do to acceleration and I personally don't mind switching gears... I love dropping a gear and hammering down.
472viper, I do believe it will be a little less responsive, but how much, who knows? I've done the "on paper" math, but that is much different that seat of the pants feel. Most of my riding is done on the highway or long country roads, so I am more concerned about that than buzzing around town.
Also, I would rather have a 3:1 rear drive than a 2.66, but if the 2.66 c90 fits without modification, that would be much easier than finding someone to manufacturer a 3:1.
Dan
dhillis is offline
post #7 of 2183 (permalink) Old 06-20-2007, 07:07 AM
Voyager's Avatar
I'd like to know the results of all this if, or when someone tries to change out the gears.
All animals deserve our respect. Some animals deserve our help. A few animals deserve a side order of fries.
Voyager is offline
post #8 of 2183 (permalink) Old 06-20-2007, 09:00 AM
isobig's Avatar
Please keep us updated!
'01 VL800 Red/Blk - totalled 6/17/2012
isobig is offline
post #9 of 2183 (permalink) Old 06-20-2007, 09:14 AM
Put me down also as being VERY interested in how this turns out.
I also don't mind downshifting to pass.
06 C50 11/05 to 3/14
14 Harley Street Glide 3/14-
77 Yamaha RD 400 4/83-
RD 400 is offline
post #10 of 2183 (permalink) Old 06-20-2007, 10:07 AM
meldooby's Avatar
I think you will make 5th gear unuseable.
the bike already won't wind all the way out in 5th. If it would, you would be going 122mph when the rev limiter kicked in, which the bike will only do going wown a long steep hill.
You are deluding yourself about the "high revs" at 75mph indicated, the bike is just lazying along.
Naked Jugs Rock!!
2004 Volusia
meldooby is offline
