My wife owns an `04 lehman Romani trike 800cc. Think I should replace the front tire with a same sized REAR tire since it wont lean?? Can/should I REVERSE the tread as well??
Sure, also find car tires the proper size for the rear and you will not only be double darkside but triple dark. You'll get alot of mileage and a better ride.
WFNR2005-2007: one of these 2007-present: one of those Accessories to date: this and that, oh and one of them |
| The Following User Says Thank You to beezer For This Useful Post: | SahZooKee (01-17-2013) |
You should put an original size motorcycle tire on the front of your wife's trike.
Trikes require enough upper body strength as it is to turn, (because it don't lean), anything larger is going to make steering heavier.
| The Following User Says Thank You to 472viper For This Useful Post: | the_snake1201 (01-16-2013) |
#6 (permalink) | |
You will not get any wear advantage by putting a rear tire in the front, either.
- 2005 Boulevard C50 - 7-2008 to 5-2012 - 2012 Vulcan 900 - 5-2012 to Present Any idiot can run a marathon. It takes a special sort of idiot to run an ultra-marathon!
#7 (permalink) |
I also agree with the Vipe, the steering on a trike is the same geometry as on the motorcycle, as nothing has changed up front.
Good Times Happen On The Boulevard And The Boulevard Is Suzuki=========================================== In Dog Beers I've Only Had One... ----------------------------------------------------- "metal monsters that let us breathe. Let us smell. Keep us from being numb" -Zookoff |
#8 (permalink) |
People put rear tires on the front of heavy cruisers and the tire you would be putting on the front of this bike sounds pretty small so disregard the naysayers advice. If your wife is larger than a small child and isn't going drifting she'll be fine.
Hope this helps
#10 (permalink) |
As far as a car tire, you have spokes. Unless you are going to a cast wheel or sealing the spokes bike tire makes sense. Rear tires are reversed in front because of the way water is dealt with, pattern of treads, if you use on front, reverse tire.
Welcome to the site, is your wife on the site?
