Oil - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 11 (permalink) Old 12-22-2012, 04:48 PM Thread Starter
C50T Rider's Avatar
Oil
How much oil does a 2008 c50 hold?
C50T Rider is offline
post #2 of 11 (permalink) Old 12-22-2012, 05:05 PM
Kyleh1214's Avatar
3.5 quarts if you do the filter change
1974 Honda CR250 (2003-2006)
1984 Kawasaki GPz900 (2009-2011)
2004 Suzuki Volusia (2012-2013)
2004 Victory Touring Cruiser (2013-20##)
Kyleh1214 is offline
post #3 of 11 (permalink) Old 12-23-2012, 03:15 AM
Yes. Manual says 3.6 but it will vary coz a little oil always remains behind and the engine always has sludge. Start with 3.4 if ur changing filters and 3.2 when ur not changing filters. Then add little by little till you reach full mark
Againstallodds is offline
post #4 of 11 (permalink) Old 12-27-2012, 06:41 PM
I juz did an oil change and strangely the bike took 3900 ml...... Maybe coz i flushed the bike with wynns before the oil change. Sludge gone. I added 3400 ml and kept adding 100 ml till i reached the full line.
post #5 of 11 (permalink) Old 01-02-2013, 12:57 PM
dohebert's Avatar
I can get about 4 gallons in my saddlebags.
dohebert is offline
post #6 of 11 (permalink) Old 01-03-2013, 11:55 AM
bipestuff's Avatar
Yup, my oil changes are pretty consistent with the manual.
2007 black C50T (current) - PGR Member
1973 Kawasaki (first bike)
My Gallery
bipestuff is offline
post #7 of 11 (permalink) Old 01-12-2013, 01:50 PM
Had to drain oil.... The slightest lean on the left gave me wrong readings. Now onwards i will put 3200 ml and wont check the window....
post #8 of 11 (permalink) Old 01-12-2013, 02:17 PM
Gene's Avatar
I would put in the 3200 ml and then check the window while using a bubble level accross the seat of the bike or under the frame. That way you know what 'FULL' looks like.
06 C50C (Special Edition)
CYFHMN member ---
Gene is offline
post #9 of 11 (permalink) Old 01-12-2013, 03:03 PM
I tried tht. Dint get a perfectly parralel place to the ground on thebike. Inspection mirror better. But honestly 200 ml less or more wont hurt thebike...
post #10 of 11 (permalink) Old 01-12-2013, 04:04 PM
t-man403's Avatar
I dumped in a full 4Lt and never a had a problem.
t-man403 is offline
