Banned
Noticed that some members are putting Seafoam in their engine oil and running that way.
Seafoam is a mixture of ordinary oil at 40-60%, Naptha at 25-35%, and IPA at 10-20% Naptha is gasoline purified to have a low vapor pressure (also known as "white gas") IPA is Isopropyl Alcohol or Isopropanol - a form of alcohol. Here is some information from another site: cleansed, not coated On the other side of the engine block are those additives which will cleanse your engine, not coat it. Stuff like Bardahl, Rislone and Marvel Mystery Oil claim they can make your engine run quieter and smoother, and reduce oil burning. These are products which contain solvents or detergents such as kerosene, naphthalene, xylene, acetone or isopropanol. If used properly, I suppose these products will strip off your Teflon and zinc protective coatings! But unless you have a really old and abused car, you probably have no need of stripping away sludge and deposits from your engine. Thus, you probably have no need for these wonder cleaners. If you overuse such products you can damage your engine by promoting metal to metal contact. If you use a synthetic oil, such as Mobil 1, you are advised not to use any engine treatments or additives. Mobil claims that The use of an engine oil additive is not recommended, either by Mobil or by virtually any vehicle manufacturer. In fact, it may void your new-car warranty. |
It's not meant for permanent use in the oil; it's meant to be driving for the last ride before the oil change. I hardly think that would cause any damage or SeaFoam, a renowned manufacturer, wouldn't recommend that type of use.
Carsten 2004 BMW R1150RT 2006 Yamaha Stratoliner S (sold) 2006 Kawasaki Nomad 1600 (sold) 2005 Suzuki C50 (sold) |
#3 (permalink) | |
Banned
Yep, guilty
Visit www.volusiaowners.com/viewtopic.php?=8&t=862 ... PM me to get your BIKERPOP SSS Strap Black & Chrome '05 DJ800 Official "Mountain Beta Tester" DJ Drive Mod! |
#5 (permalink) | |
#8 (permalink) |
Ya know,
These additives aren't much help. I've been tearing down and building engines up as a hobby 7\8ths of my life. I have never seen any torn down motor clogged or sludged unless oil was seldom changed, overheated, block was split or the head gasket leaked. I just built a 460 last year that had 180,000 on it. It was clean as a whistle inside, of course it had good regular maintenance also. It was in a truck I bought new, I never used any kind of additive in the motor. I just believe anything outside of the recommended oil\filter changes are not going to help or enhance anything. If a motor isn't running right, it's broken. 2 cents |
#9 (permalink) |
I grant you that the modern oils, with the detergents and all the other refinements already in them, do a much better job than the old Paraffin based oils that used to "gunk up" an engine. I pulled engines apart when I was a teen [ in the 50's ] that you had to scrape the sludge out of with a putty knife. By comparison, in '83, I rebuilt a slant 6 in an old Plymouth Duster that was very clean. .. All that doesn't negate the fact that seafoam in my C-50 crankcase keeps my shifter from getting stiff at 2,500 miles so that I can get the 3,000 miles out of the oil I am supposed to. A local guy I ride with told me: when his shifter gets hard to shift, he changes the oil. He pays little attention to how many miles is on the odometer. It's an older Vulcan with fewer resetable trip meters, and he don't keep written records. .. My sense is, and this has no research by me to back it up, but, I feel like the seafoam makes the oil slippery-er. Perhaps by keeping the contaminents in suspension so that they do not cling to the surfaces involved, causing the shifter to stick. We are talking: "at the molecular level" here, and only a scientist, who studies this chit, could say what is happening for sure. I just know it works for me.
#10 (permalink) | |
![]() 2007 Street Glide SE 103 BB, SE255 Cams, Ported and polished heads, FM Jackpot dyno tuned mufflers, PC Vision tuner, and a whole bunch of other goodies. |
