MC Enterprise engine guard / crash bar - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
Old 12-22-2012, 09:43 PM   #1 (permalink)
Default MC Enterprise engine guard / crash bar
MC Enterprises Engine Guards for Volusia 800/C50 '01-up - 1000-24
i'm 95% sure this is the crash bar i picked up a few months ago. i picked them up used off ebay, the seller was parting out a 2003 Volusia. Does anyone on here have this particular brand of guard or one similar? i'm finally getting around to installing it and I cant find any good images of how it bolts to the lower part of the frame. i think i can see how it bolts up to the frame but i'd like to make sure without guessing. it almost seems like i am missing something to finish the install.
danteisme is offline   Reply With Quote
Old 12-22-2012, 09:57 PM   #2 (permalink)
do you have any close up pics of where yours bolts? i don;t think this will fit on the bike any other way.
Old 12-22-2012, 09:59 PM   #3 (permalink)
they're pretty straight forward. The open end goes on the bottom. Loosen the bolts, pot it on and tighten. Just look at the picture, it's pretty hard to get it on wrong. it only fits one way. Just make sure you put lock washer or some locktite as I've read that some have had the bolts come loose while riding, and that is not good!!!
Old 12-22-2012, 10:04 PM   #4 (permalink)
cavie's Avatar
There's only one bolt there to put it on. It's the forward bolt holding the foot peg and brake assembly on. Just remove the bolt and replace it thru the bar mount. there is one kust like it on the cluch side. My cobras mount on the same bolt only on the other side.
Old 12-22-2012, 10:08 PM   #5 (permalink)
Thats the part i wasnt sure of. If they shared the bolt with the floorboards. They dont fit going on the outside of the board mounts, the only way i can get them on is the guards first up on the frame, then the boards and tighten the bolt down. Do i need a spacer or anything to make up that thickness difference from the front to the rear of the board mount?
Old 12-22-2012, 10:31 PM   #6 (permalink)
cavie's Avatar
That's how it works. no spacers. My Cobras are designed the other way with the solid bar on the bottom and the space on top. Because of that, I have to remove the bottom bolts everytime I chane the oil filter. You wont,
Old 12-22-2012, 11:24 PM   #7 (permalink)
Good to know. It just didnt seem quite right so i figured i need to double check before i start cranking bolts down
Old 12-23-2012, 02:11 AM   #8 (permalink)
I would suggest fat rubber washers between the bike frame and the gaurd/brake /gear shifter. And swapping out the bolts for stainless steel, longer ones.
Less vibration. And tighten them real good. U wont need to remove them if ur changing the oil filter like cobra bars.
Old 12-23-2012, 02:18 AM   #9 (permalink)
Rick77's Avatar
Ummm........ Mine came with spacers.
">2008 C50T June 2008-January 2010/ 2008 Honda ST1300 January 2010-.........?
Rick77 is offline   Reply With Quote
Old 12-23-2012, 08:07 AM   #10 (permalink)
Doh! Spacers for the rear part of the boards?
