Seen a thread before that this would work so I took the plunge and bought the kit. It does take some modding but it works and looks good. This is on my 2007 M50.
![]() M109 Cone Air Filter by shaun_seeley@rogers.com, on Flickr |
| The Following User Says Thank You to opticpros For This Useful Post: | IACOB AURELIAN (12-22-2012) |
Here's mine. Used a Thunder intake kit and a spike filter for a Yamaha that I found on Ebay for 70 bucks. Though I was going to have to modify it but it bolted directly to the thunder adapter.
2003 Volusia - Teal/Silver, Lowered 2", tach, kury grips and pegs, engine guards, hard mount bags, Jardine pipes,Thunder intake, Webslinger speedo. 1983 Goldwing Interstate - Black, all original. |
| The Following User Says Thank You to bc_firefighter For This Useful Post: | IACOB AURELIAN (12-22-2012) |
#6 (permalink) |
Here's how I did it: Custom intake and filter
| The Following User Says Thank You to Cueball For This Useful Post: | IACOB AURELIAN (01-07-2013) |
#7 (permalink) |
Cueball was my inspiration for this mod. I do have a welder at my disposole though so I remade the support bars. They are 1 1/2" bar in between the spacers with a little twist at the end with the pliers. I also welded nuts to the ends of the spacers to give the bolts that extra hold.
I took some further advise from this post Forcewinder and Spike styled intake on the cheap |
#8 (permalink) |
Can I ask what you did with the sensor plug and small tubeing that went to the stock fat box. The reason I ask is because I have a KN Filter (Cone) I'm installing. Its 54mm and the intake tube is oval (rubber) no issue there. But what do I do with the cord that attaches and small tube that went to the back of my stock box?
Thanks Ron
Love my Boulevard |
#9 (permalink) |
The M109 intake has a spot for the breather hose to hook back on, which made that part easy. As for the air intake temp sensor, I drilled a hole and mounted the temp sensor into the M109 intake (check out the pictures from my install).
