ABS cement "FAIL"!!! - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
Old 11-18-2012, 09:32 PM   #1 (permalink)
sanos's Avatar
Default ABS cement "FAIL"!!!
This is a follow-up of this thread... Tail light mod...
Good news is my tail light mod turned out pretty good!
Now the bad...FAILED on filling the fender holes using ABS cement.
After the bike was sitting out in the sun, I noticed that the fender where I used to fill the holes started to expand and thought the paint had bubbled-up.
It also felt soft to the touch.
This is what it looked during painting...
Ater couple hours in the sun...
Now what???? This SUCK!
sanos is offline   Reply With Quote
Old 11-18-2012, 11:03 PM   #2 (permalink)
Try JB weld to fill the hole. It'll become hard and sandable. It should not expand or shrink.
I hope it'll works for you
Deafvl800rider is offline   Reply With Quote
The Following User Says Thank You to Deafvl800rider For This Useful Post:
sanos (11-19-2012)
Old 11-18-2012, 11:06 PM   #3 (permalink)
Hmmm.......
I used ABS cement on mine, but I used sheetrock screen as a backing and I filled over the area with a thin layer of bondo.
Mine has held up fine.
Filling those nasty holes
USAF 1973-1977
SoDak ANG 1977-2010
sanos (11-19-2012)
Old 11-19-2012, 08:51 AM   #4 (permalink)
03volusiarider's Avatar
Thats one SWEEEET bike...
Old 11-19-2012, 10:27 AM   #5 (permalink)
Rob 61's Avatar
find some reflectors & stick on there
Robyn
Ray II, 07 C50 10/11
11 Victory Cross Country 3/11-1/12
04 Volusia 7/07-4/11
I'm on top
Rob 61 is offline   Reply With Quote
Old 11-19-2012, 11:20 AM   #6 (permalink)
ABS glue is a solvent type of glue that chemically melts two parts together. More likely it was the glue that melted the plastic than the sun.
'09 C50T Black/Grey
Old 11-19-2012, 11:29 AM   #7 (permalink)
Wood Welder's Avatar
ABS cement is not a filler?
I'm sorry this happened to you......btw, nice mod you did to your bike.
Thickness can't be measured!
VR WESCALERO MEMBER
Wood Welder is offline   Reply With Quote
Old 11-19-2012, 11:54 AM   #8 (permalink)
t-man403's Avatar
If it was me doing this I would be using fiberglass.
If you don't want to do a lot of sanding put a small patch of fiberglass on the inside of the fender and cut a couple of pieces to fit in the holes so there is some substance for the resin to hold on to. Fill the holes level with resin. for easy sanding and finish, a bit of bondo on top.
Old 11-19-2012, 01:23 PM   #9 (permalink)
Fiberglass will likely work but, the fenders aren't made of fiberglass....They're made out of plastic so why not use plastic weld?
https://www.acklandsgrainger.com/AGI..._code=DSSXPSA1
VR WESCALERO MEMBER
Old 11-19-2012, 02:14 PM   #10 (permalink)
If it were mine i would just buy some of those bullet license plate holder bolts and put in those holes i think that would look pretty cool.
gkeefer is offline   Reply With Quote
