Using the license plate post bracket and back plate to mount the after market universal light.
![]() I also used the old OEM tail light reflector bracket to mount the mini turn sig lights. The aluminum pack-plate still needs to be trimmed-off around the maltese light. Not sure if I like this set-up yet. Just found out that this light only have two wires for the running and brake but will not work because it needs a ground wire added to it. ![]() ![]() When it's all done, it should look like the tail light is floating behind the fender... ![]() ![]() Hmmmm....................
Havent seen those wheels before- What are they from?
#7 (permalink) |
Update:..... filled the holes, drilled holes for the wiring and where the license plate will be. And rattle painting
![]() ![]() drilled holes on inner fender brace... ![]() The backside of the fabricated tailight... ![]() ![]() ![]() ![]() paint drying...
#8 (permalink) |
Look'n good, thank you for the updates on the progress.
2008 Burgman 400 '08-current 2003 Volusia Annie '12-current De-badged, Honest Abe ![]() Facebook: Colorado Volusia Riders |
