#71 (permalink) |
Agreed, definitely chop off the extra pipe. Gonna have to make this a weekend project soon. I will report back with a sound clip. Probably will be a week or two before I can get to it.
#72 (permalink) |
Id-man... you mentioned before, that to take out the cyclops plate to get a heavy duty extension for the 3 inch hole saw. I have been looking for one, but cant find anything that will work with the arbor for 3/8 drive. Can I beat it with a pipe like I did with the mickey plate? Or does someone know where I can find the proper extension. I prefer to cut it out, since by beating the mickey plate it didn't leave a smooth surface from where the welds broke free. I would imagine that i would have to smooth it out to fit in the glasspacks? !
#73 (permalink) |
Hey Dannyrider13, I can tell you that I used a Milwaukee 7/16" Quik-Lok Extension in a very beefy 1/2" drill. I would not recommend going out and buying such a beast unless you can justify the roughly $25 price tag by using it on other projects (I was lucky enough to have one available to borrow). I am not sure if it would fit in a 3/8" chuck. I am also not sure if bashing out the cyclops plate is a good idea for the same reason you state...I started out by beating my Mickey plate with a pipe too and things were getting pretty ugly inside that pipe, ripping the perforated liner. So I quit and got the right tool. Once I had the good setup I was able to ream out the bore with the hole saw and clean everything up, trimming away the uglies. Reaching in to remove the cyclops was a cinch...hole saw is definitely the way to go - or the new method of cutting away the outer lip and pulling the guts out as one piece. Whatever you decide to do, take pics and share.
.. ,,,,,,,,,,D/_ ,,,,,,,,,,/(_`._,-. _____(o) `--'(o)_____ 2006 C50T. Almost stock except for gutted pipes with glasspacks, Homeboy seat pan mod, Cobra crash bars, and NAPA 4416 running lights.
| The Following User Says Thank You to id-man For This Useful Post: | Dannyrider13 (10-12-2012) |
#76 (permalink) |
My 2006 model did not have O2 sensors....can't tell you.
#78 (permalink) | |
I'm loving the idea of this Mod but I'm really not into big noise, but I love the bass that you got. I've made a few glasspack mufflers myself from stainless tube and perf sheet for go carts. They are really easy. I was thinking of rolling a 12" long tube from perf sheet the same diameter as the header pipe instead of 2". Weld some donuts each end. wrap them in glass insulation materiel and put them in.
#79 (permalink) |
I took the whole cat plate out with a hole saw. I can't remember now if the heavy-duty extension I used made it in one piece or if I added multiples together. Sorry I didn't actually measure how deep the cat is in there. What I can clearly (and painfully) remember is that my first attempts, trying to string together a couple light weight POS extensions fought me every step of the way - kept slipping in the drill's chuck AND losing grip on the hole saw - an utterly frustrating waste of time. I had the same sad luck trying to bash out the parts with a pipe - was just making a mess, ripping up the insides of my pipes. Highly recommend getting the heavy-duty extension(s) and a nice sharp bimetal hole saw and a strong drill motor with some good torque to it. Doing this project with the right tools is simple and easy.
#80 (permalink) |
Oh, and about loudness...
I think making up your own glasspacks is valiant. I wouldn't try it but only because I am totally satisfied with both the tone and volume achieved with the pre-made 12" ones I used. Volume is already about 1/2 to 1/3 of the gutted decibels. I was a little shocked at first how much it hushed the loudness, but equally and immediately as pleased with how it brought out the rumble. I guess if you're making your own you can theoretically craft your own perfect balance of volume and rumble based on length and how many wraps of glass. Sounds like a cool project...let us know how it goes.
