Thought I would consolidate all my mods into one thread. Here there are:
Stock as I picked her up ![]() ![]() ![]() ![]() 1st mod, strip her down! ![]() Deleted the windshield, front reflectors, front turn signals, saddle bags, rear seat and sissy bar. More to my liking now! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 2nd mod, Radiantz LED Tail light board, rear clear red LED turn signals and front clear amber LED turn signals ![]() Stock look before the change ![]() Got the red light cover off ![]() Radiantz LED board in place, added a bit more double sided tape, as the provided tape wasn't enough to my liking! ![]() Testing before I close up the light ![]() ![]() Light closed up ![]() Closed up and Lit up ![]() Then I went to install the LED turn signals, and the left side installed in a few seconds. When I got to the right side, I found out that the previous owner had replaced the turn signal, with what I am assuming is an older turn signal, as the bulb base is not the same as the other side. Luckily the PO did provide me with the turn signal that he replaced in case I needed an extra lens. I tried the LED bulb holder in that, and it fit as it should. So now I have to do some wiring to swap over that bulb holder into the turn signal that was replaced. So since I couldn't do the turn signals, I decided to get the hair dryer out and remove that sticker from the fender ![]() This thing did NOT want to peel off. Anytime I would get a good portion peeled enough to pull, it would just crack off. After a good 20 minutes of scrapping it off with my fingernails, I got it all off. Had some Goo-Gone handy to get rid of the residue, but wasn't able to get it fully off. Anyone have any better luck with it? 3rd mod, custom license plate! ![]() 4th mod, got myself a Mustang Wide Touring Vintage seat! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Pics of the seat on the bike to follow. I installed it last night and then went for a "test drive" so didn't really get to a picture! Thanks for looking and I will be updating this thread as time goes on and more mods get done! Not bad for having the bike for 3 weeks right?
Location: Region of Waterloo, Ontario (Home of the "Blackberry" and the "Blue Box")
Nice, but, how are you getting away without front turn signals, here in Ontario?
(Are you sure it's a "T"? Should have "White Walls" on it, unless they were already taken off?) |
'scuse the Noob Q, Don't you have to install anything special for the LED lights? Or are they direct replacement?
2009 C50T Black/Grey Cee Bailey's Shield/Stock Mounting Hardware, "Honest Abe" Mod, "BB Drive" - Modified VS1400 drive, Mustang Wide Touring 2-piece seat, MC Enterprises Highway Bars, Metzler ME 880 Tires, GBushing
#6 (permalink) |
When you do a direct replacement with the LED signals, you need to check with your local laws to find out if there is a bpm (blinks per min) requirement because the LEDs flash at a whole lot faster rate than the incandescent. I know it's ridiculous but there are laws out there about this. You can counteract that by replacing the flasher with an LED flasher. Look in the Custom Mods Section for LED Flasher Mod.
_____________ 2005 C50 R.I.P. 2006 HD Street Glide...V&H Fuel Pak with V&H True Duals and Stage 1 Air... S.F.F.S. SOTMC |
#7 (permalink) | |||
#8 (permalink) | |
I'm looking into the tail light LED's for my Nomad, thanks for the pic with info.
#9 (permalink) |
Seven,
If You used the two-sided sticky tape to mount the LED board, You might want to go back into the taillight and use 5 minute epoxy to secure that LED board. The sticky tape dries out rapidly, resulting in an unfastened board.
#10 (permalink) | |
Thanks! I plan on going back in their this weekend, because as you stated, the double-sided tape has already come loose. Any specific brand of 5 minute epoxy to use? |
