Air Cleaner? Aftermarket? Reviews? - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
post #1 of 16 (permalink) Old 02-25-2012, 10:04 AM Thread Starter
emtnfirefighter's Avatar
Not sure if this is the right section but it is a mod so I am going to give it a try.
I have a 2009 C50 Boulevard and I am looking to put an aftermarket air cleaner on my bike. The current OEM one is too wide and I am looking for something thinner?
Anyone have any advise or reviews?
So far I have looked online at:
Baron Custom Accessories Big Air Comet Kit | ZZ41503 | J&P Cycles
or
Baron Custom Accessories Big Air Smooth Kit | ZZ41505 | J&P Cycles
Last question what is the skill level for DIY replacement?
2009 SUZUKI C50 BOULEVARD SPECIAL EDITION
Mods: Crash Bars, Ipod Charger, 12 volt accessory outlet, Ultimate Solo Seat, Windshield, VA Lowers, Shark 250 watt radio, Tank Bib, Vista Cruise, Windshield Bag, Custom USA Flag, Highwway Pegs, and rear fender rack.
emtnfirefighter is offline
post #2 of 16 (permalink) Old 02-25-2012, 10:29 AM
King-Pin's Avatar
I think the most important thing is that YOU like the looks of it.
The real performance addition will be a fuel processor. Usually adding an aftermarket intake goes hand in hand with adding a fuel processor.
So be sure to find an intake that you like and go with it.
'72 750 Four
'86 Virago
'07 C50T
'07 Nomad
King-Pin is offline
post #3 of 16 (permalink) Old 02-25-2012, 10:32 AM Thread Starter
Can I use either of the 3 above without a fuel processor?
I am not really looking for it to be performance mod, more of a comfort mod since the OEM one is so wide and on long rides digs into my right leg
post #4 of 16 (permalink) Old 02-25-2012, 10:36 AM
King-Pin's Avatar
Maybe. a few have added an aftermarket intake and didn't add a fuel processor. However, if you do, your bike is likely to run too lean and cause other problems.
I would spend some time searching the "Mods" forum. In most cases folks had to add a fuel processor, not necessarily for the performance, but to keep the bike from running lean, popping, and backfiring
'72 750 Four
'86 Virago
'07 C50T
'07 Nomad
King-Pin is offline
post #5 of 16 (permalink) Old 02-25-2012, 10:36 AM
Yeah, I own a 2002 VL 800 - the c50's older brother, I suppose- and found it very difficult to find any aftermarket air kits that I like AND fit the bike. Because the air intake hose comes from the top and point down instead of side to side, I found myself either fabricating some kind of connection or paying the bux and getting the Thunder Mnfg. adapter (which comes with a jet kit , btw). If you opt for the thunder adapter, it opens up a whole lot more air intake possibilities.
http://www.thundermfg.com/store/inde...oduct_list&c=2
somarosa is offline
post #6 of 16 (permalink) Old 02-25-2012, 10:37 AM
its pricey, though...
somarosa is offline
post #7 of 16 (permalink) Old 02-25-2012, 10:38 AM
King-Pin's Avatar
A rejet kit wont do him anygood as his bike is fuel injected.
'72 750 Four
'86 Virago
'07 C50T
'07 Nomad
King-Pin is offline
post #8 of 16 (permalink) Old 02-25-2012, 10:55 AM
Hi-Vis's Avatar
emtnfirefighter, I have the exact same problem. I'm 6'4" and my right leg and the football (air filter) fight over real estate. I don't care what it looks like as long as it does not burn my valves or piston from too lean of a mixture.
I guess this proves that the man who designed this bike is not over 5'5" as a shorter person fits perfect.
Would an EGT help with tuning?
Special Edition 2009 C50 Green/White . 14200 miles. Loaded up and then some!
ATGATT Sweat, not blood.
Hi-Vis is offline
post #9 of 16 (permalink) Old 02-26-2012, 10:29 AM
dsmitty's Avatar
I have the GMan stealth intake - it uses the stock air box cover. Much lower profile; my leg used to rest against the air box, now I don't notice it at all. Complete the mod with a fuel processor and pipes - you will notice a definite power increase.
I put pictures of the intake in my album when I installed it.
2009 C50 (3/2011 - 3/2014)
2007 Street Glide (2/2014 -)
San Jose, Ca
dsmitty is offline
post #10 of 16 (permalink) Old 02-27-2012, 10:34 PM
meiklejohn's Avatar
Definately consider the Thunder Mfg. option - Yes it is a little more pricey but well worth it!
meiklejohn is offline
