What size is the rear axle? - Suzuki Volusia Forums : Intruder Volusia and Boulevard Forum
Old 07-15-2009, 06:25 PM   #1 (permalink)
Glutes's Avatar
Default What size is the rear axle?
Hi, I'm looking to install a horizontal side-mount license plate and I need to know what size the rear axle is? The mount I'm looking at says it is for 3/4 inch axles. Thanks mucho, and sorry to bug you wrench heads with a question I should know, lol.
Glutes is offline   Reply With Quote
Old 07-15-2009, 07:04 PM   #2 (permalink)
OregonLAN's Avatar
The hole in the brake plate is roughly 11/16". If the bracket is pre-drilled for 3/4" it would have aproximately 1/16" play in the bracket where the shaft went though it. Is that what you were looking for?
OregonLAN is offline   Reply With Quote
Old 07-16-2009, 03:58 PM   #3 (permalink)
Glutes's Avatar
I apologize wholeheartedly and unreservedly for asking this silly question. I found my answer almost immediately after I posted this. Thanks for the help tho Oregon. I am a KNUCKLEHEAD!!
Old 11-08-2012, 11:29 PM   #4 (permalink)
Default trying to install a side mounted license plate...
Heck, what is the answer and where did you find it? Is the 11/16" correct?
daharris03 is offline   Reply With Quote
Old 11-11-2012, 08:51 AM   #5 (permalink)
03volusiarider's Avatar
I used the bolt on the left side above the axle for my side mount license plate.
